Auditioned Sennheiser HD-26 PRO
Mar 28, 2014 at 12:28 AM Post #121 of 141
Hmmm...I'd maybe put them on par with the original HD25s aesthetically, but the new aluminums are definitely better looking IMO. Sure the HD25 has exposed cabling, but then the 26s have those plastic adjustable wings sticking out; at least if the cable breaks, it can be replaced.
Apr 1, 2014 at 1:52 PM Post #122 of 141
One thing to consider: If you don't mind the size and weight difference, you can get the FiiO E12 plus Beyerdynamic DT 770 PRO 250 for roughly the same price as the HD 26 PRO. Now that is a sweet combo!
Apr 4, 2014 at 5:15 AM Post #125 of 141
Hi everyone,
I have been using the sennheiser px200iiii with my laptop and mobile for the last few months. I am looking for a small, portable, sealed solution to upgrade from that that is drivable by smartphones. I have been thinking about the new beyerdynamic t51p or the hd25alu or hd26pro. A pity that neither of those has an inline remote or mic though because i really need those. At least with the last two options you might potentially be able to switch the cable. Any news on  what the connection on the headphone end of the hd26pro is like?
Any comparisons between the hd26pro the hd25alu and or the t51p would be greatly appreciated.
Greetings, Anouk,
May 13, 2014 at 10:18 AM Post #126 of 141
Amperior is everything you're looking for. Even has the mic.
Hi everyone,
Greetings, Anouk,
Aug 3, 2014 at 9:57 AM Post #128 of 141
Hello,
Does anyone have the '26 Pro and the '25 Aluminium? Is the Aluminium far behind?
The capsules/cups of the '26 Pro; do they fit the headband of the '25? I have a band from another set of phones which the '25 cups are supposed to fit
The pads of the '26 Pro; do they fit the '25?
Thanks,
DT
Sep 1, 2014 at 2:15 AM Post #129 of 141
  Hello,
Thanks,
DT
Google turned this up in an instant.
They are probably using the same pads, that's as much as I can tell from this picture.
May 28, 2015 at 12:56 PM Post #130 of 141
What's happened to the HD26 ? The interest seems to have died off and availability is pretty limited. Is it the long term replacement for the HD25 ?
May 28, 2015 at 1:47 PM Post #131 of 141
I love mine. I doubt that they're as durable as the 25s, so I default to the 25s when traveling. I marginally prefer the 26s on SQ. Both are great. I don't know if they're worth the 50% upgrade (in dollars).
May 28, 2015 at 3:28 PM Post #132 of 141
I keep waiting for the price to drop, but it doesn't seem to be happening.
May 28, 2015 at 4:47 PM Post #133 of 141
That's the reason I'm interested, I'm a big fan of the HD25s. Its there mix of sound quality and durability which is hard to beat.
