miyamoto
- Sep 1, 2012
Will this be able to power a logitech Z623 or is it only for headphones?This to laptop then 3.5mm out to Z623?
BA_D_R, great choice on the DF1.2. It's a good portable DAC. Enjoy your music my friend.I just bought the dragonfly 1.2
I don't have much of experince about DAC/AMP.
I'm facing something strange, yet it can be noraml, so I hope anyone can verify it.
when i'm playing some sound test files I noticed some sort of noise at the max volume, one of the most obvious frequency is the 16000hz (16Khz) file https://www.dropbox.com/s/pwgkfpsniuhcbu2/16000hz.wav
I'm using windows 7 64-bit and playing throw foobar2000 using WASAPI event.
windows volume is set to max so as foobar2000.
the noise is so obvious between 0dB and -3dB, and a little bit of noise between -3dB and -4dB.
I have only one headphone ATH-M50 (impedance 38ohm).
please download the test file from here https://www.dropbox.com/s/pwgkfpsniuhcbu2/16000hz.wav
Is that normal or I got a bad (dysfunctional) Dragonfly 1.2?
I bough it from Crutchfield (Audioquest authorized dealer)
the dragonfly is connected to USB3.0 which is capable of delivering 900mA.
I tried it on my PC and my laptop with the same result.
Another thing, is it advisable to set WASAPI (Hardware buffer event mode) to 0, or it doesn't matter https://www.dropbox.com/s/hob9ntqvyq2u9ur/foobar2000%20setting.jpg
I already own Asus Xonar ST, and I think the Dragonfly 1.2 is better than it, later I will post an update.
Thank you...
Thank you...
BA_D_R:
Just had a listen to that 16kHz tone with the Dragonfly 1.2 using 62-ohm Sony MDR-V6 and also 300-ohm Sennheiser HD800.
Sounds fine with both. No unusual distortion/noise, just annoying high pitched tone
I managed to borrow this unit from my friend, ran some measurements and wrote a review:
http://archimago.blogspot.ca/2014/08/measurements-audioquest-dragonfly-v12.html
Not bad. It puts up some decent numbers and sound quite good...
I have both the Dragonfly 1.2 and the E17, if I am using my MacBook Pro in my study, I tend to use the optical out into the E17 as a DAC that then goes into my Marantz Amp. However, if I am on the road then I use the Dragonfly straight into my HD600's. Obviously this gives me two signature sounds, but, I am more than happy to use the DF and the Sennheiser's at length when I am writing up reports and chilling after work stuck in a hotel room. I also like using the DF in my MacBook if I am catching up on downloads from iPlayer late at night sitting next to Mrs Rearwing.
How would the DF 1.2 compare to the schiit modi/magni stack in terms of sound quality. I have a MacBook Pro.
I own Dragonfly v1.2 and totally agree. That's why I am selling it now.
Voices sound thin, unnatural and lack body due to the absense of lower midrange.
About the treble, zerolight has explained everything.
If that matters,I listen from the DF 1.2 with Philips Fidelio X1.
I don't understand all the hype about DF 1.2 as I consider it as a mediocre product regarding sound quality.
