Bostonears
- Jan 30, 2003
Sennheiser 414 pads do basically the same thing at 1/3 the price
I agree... as long as you don't mind the screaming yellow color.
I am wondering, can i use this as just a dac and then connect it to my matrix m-stage?
So i just hook up a 1/8 to 2rca and then plug that into my amp. Will there be any interference or something like that with the signal getting amped twice?
If you put the system volume and media player volume at 100%, DF won't amplify the signal.
Really? I didn't think there was anyway to bypass the amp in the DF; I though fixed output was really just max volume.
http://www.audioquest.com/pdfs/dragonfly/DragonFly-FlightManual-EN.pdf
"DragonFly is also capable of being employed as a traditional fixed-outputsource component (such as a CD, DVD or Blu-ray player),
and can be connected to a standard input on a receiver or preamplifier. For this application, both the music player’s volume control and the main operating system volume control should be set to maximum. This “fixed output mode”allows your audio
or AV system’s volume control to be in charge."
Any of you have experience listening to both dragonfly 1.2 as well as schiit modi/ magni combination OR the meridian explorer? Your thoughts on how the dragonfly fares against the others? Trying to decide on what dac/ amp to pair with my macbook pro and monster miles davis trumpet IEMs.
Got my DF 1.2 in today. Plugged it in and the bass was out of control via my SE846. I left it and went to lunch and the bass has tightened up a ton. Sounds good. Only problem for me is the gain is so high, I have my computer volume at 1 or 2 and its loud enough for me to use at work. I only plan on using it with IEMs so maybe its overkill and I should try something else out. Other than that, no complaints. Looks and sounds good.
