davek
- Jan 6, 2011
Hi! I just bought back my R70x 2 days ago to give it a chance with my NAD D3020 (previously I sold the R70x because it was a bit too polite and grainy in the highs). The D3020 does magic with my MSR7 so I thought it would be a good match with the R70x as well. Unfortunately that wasn't the case, the top end was about the same as before, but then I remembered that I've ordered an aftermarket earpad for it when I had it but sold the R70x before it arrived so never had a chance to try it out. So swapped earpads and now I couldn't be happier It's a PU leather earpad with similar dimensions, but it doesn't have the angle and also a bit thicker. Result is awesome upper mids/highs, not the elevated and piercing AD900X like but clean and lively ones. Grain is all gone, bass is even more solid, soundstage is a bit narrower but also deeper at the same time. It's not as upfront either, imagine as if you'd take a step back, but that's all. To me it sounds much-much better compared to stock pads, I don't really understand the concept of that shallow earpad. Shorter distance to ears usually means less highs which can help (too) bright headphones but that's not the case with the R70x, it craves for a bit thicker pads.
