MattTCG
- Jan 22, 2012
^^ For the money, I'd go with Modi 2 MB.
Hi, please can you help me choose DAC+AMP to r70x, which I'm considering to buy? The DAC would be plugged to PC or cell phone via USB. The options are:
1) Schiit Modi 2 Uber + Magni 2 Uber
2) Schiit Modi 2 Uber + Valhalla 2
3) Pro-Ject Head Box DS
4) Creative Soundblaster X7
Thanks!
Anyone bother to give these headphones a real review with proper measurements and sensible wording?
So far, what is the best replacement pads for R70x? Which don't change the sound much.
Does anyone happen to know the pad dimensions or how it stocks up to the K240?
I had to take off the top wings (I call it my "big head mod") and bend the outer metal to fit better. They are so light, it didn't need wings. Even then I couldn't get them to reach fully to the bottom of my ears with the stock pads so I needed a solution that would fit longer. So I got these. http://www.nvx.com/earpads They are more soft than the Brainwavz HM5 pads (that also work on these cans. They now fit perfect, I can wipe skin oil off vs the absorbent stock material, the frequency response did not seem to change. I'd gotten the less expensive non-angled versions, I think angled versions work. A little stretching, and careful fitting, and it is on.
Thanks for your suggestion! I'm living in the tropical country, -It is hot all the time, i'm afraid that the leather pads could make me sweat. Should i buy both the NVX & the HM5 hybrids pads?.
