Audio-Technica ATH-R70x - In-Depth Review & Impressions
post-11644422
Post #196 of 1,830
earfonia
Singapore
Singapore
  Very nice. I am curious about the cables you made. What did you use to prevent the wires from pulling away from the plug? Epoxy?
Actually none. The wire from the LyxPro cable is rather thick, strong enough to withstand certain pull force. At the headphone ends, the heat shrink is rather tight fit with the cable hole of the 2.5mm connector. At the 3.5mm end, inside the jack there is the common clamp for the wire. So far so good, and I always hold the connector when pulling out, not the cable, so no problem so far.
post-11645365
Post #197 of 1,830
chongky
On the same topic concerning the HD600 and ATH-70x which is better for classical music well amped? I have the Fidelio X2 which I found a bit too warm for my taste, especially on classical tracks.
post-11645388
Post #198 of 1,830
Pokemonn
pokemon town
pokemon town
IMHO, those headphones harshness rateing is...
 more harsh    X2 >>> HD600 >>> R70x   less harsh
all up to your preference... i choose HD650 for classical music.
post-11645573
Post #199 of 1,830
Rocko1
Thanks for the reply. Got it.
post-11645708
Post #200 of 1,830
earfonia
Singapore
Singapore
For my preference, I do prefer brighter sounding headphones for classical music, brighter than both R70x and HD600. I prefer something like T1 or HD800. DT880 also a good headphone for classical. The cheapest option would probably Philips SHP9500.
post-11646425
Post #201 of 1,830
fumoffuXx
Not sure if my input matters, haha i tried the r70x thru a N6 raw with high gain and about 60 volume it sounds absolutely amazing. Then i tried it thru N6 > bravo audio v2( new mullard) sounded...mehh i find the r70x truly comes to life with neutral sounding sources? Then again i need to tried it with the bravo stock tube haha. But now N6 raw is absolutely killing it haha only like 6 hrs burnt in! :) Loving it
Reactions: twister6
post-11646431
Post #202 of 1,830
twister6
twister6 Reviews
Website
twister6.com
Loving it
If you have Cayin C5, try it with N6/R70x - epic combo!!!  But I do like it straight out of N6 as well :wink:
post-11647522
Post #203 of 1,830
DGG32
I have been enjoying the r70x with my fiio x3ii+ cayin c5 for about a month now and i have not tried the n6. In your opinion, is the improvement in sq worth the upgrade from the x3ii to the n6?
post-11648042
Post #205 of 1,830
Pokemonn
pokemon town
pokemon town
can anyone compare this to Shure's SRH1840?
R70x high is little bit weaker than SRH1840s high.
R70x is little bit warmer than SRH1840.
but R70x is little bit more organic and natural sounding than SRH1840. SRH1840 sound synthetic for me.
If you want a professional monitor headphone(i mean not for listening), SRH1840 is little bit better. IMHO.
Reactions: kawaivpc1
post-11648256
Post #206 of 1,830
fumoffuXx
to me x3ii is dark sounding, n6 is brighter with very large soundstage strong bass as well. well i havent heard x3 with the r70x so yea lol thats the description i got for it lol
post-11648975
Post #207 of 1,830
kawaivpc1
Any comment on sound stage comparison?
SRH1840's sound stage is more 3D than that of HD650.
post-11651159
Post #209 of 1,830
fumoffuXx
Hey earfonia. Read ur review on the sb x7. U able to pair it with the r70x?
Users Who Are Viewing This Thread (Users: 0, Guests: 3)
