petuloo1984
- Jun 1, 2011
Try giving it some time.
I have 2 sets of ES10s.
One used pair which I've used for around a year.
Another pair I got together with my ESW11LTD. This pair stays at home almost exclusively (to prevent scratches) and I only use it once in a while.
I just compared to 2.
I can say the burn in does tame the sound. It isn't a heaven and earth difference, it's just subtle, but enough to make it more enjoyable.
You can also try pairing it with a good amp. It benefits quite a bit when paired well with an amp.
It makes the bass a lot more controlled and midrange less muddy.
If the bass is too much for your liking, try pairing it with an amp with a slight bass roll-off. It'll clean up the bass.
Alternatively, try the ESW11LTD. It's a more refined version of the ES10.
Personally I like the ES10 for EDM, etc...
Everything else I prefer the ESW11LTD.
Hi..is there bass much different between es10 and esw11? I have es10s and love bass from them...Im listen mostly EDM..like trance,chill step,drum and bass...But cable got broken and Im looking for replacement..Can bid some esw11ltd... Love wood finish much more..
