ginetto61
Yes you are right - LAN ethernet AOIP is inherently superior due to it's native galvanic isolation, and electrical structure (no 5VDC power running along with the data stream).
Remember USB UAC was a work around and was never even accepted by Microsoft - without support even in WIN10. From what I have read they just did not like the violation of the original USB protocol. Why MS has chosen to ignore UAC is a mystery to me. But they certainly embrace ethernet IP.
Now there have been proprietary ethernet CAT5 solutions for Computer audio for over a decade - but not necessarily LAN compatible or IP based. So this is really a major change in the computer audio landscape.
I have a PCIe EMU1616M that is very good and uses CAT5 - so we have come full circle. The difference now is the holy grail of an emerging common communications std for AOIP.
This now provides the guideposts for equipment manufacturers to design around - to build a truly accepted audio standard like SPDIF and USB - so establishing AOIP as the next evolutionary step in high end computer audio.
And for us audiophiles - without the need to have a shared master clock timing many devices on a LAN - even better. As the clock can be in the interface and usually easily supplemented with a better ext word clock.
Hi and thanks a lot again for the very valuable advice.
So in the end we just need some good bridging units like pcie adapters and ethernet to spdif converter ?
This way we could feed and keep our old and loving dacs with these interfaces with excellent results in terms of sound.
I wonder if are they really so difficult to design and build. Is this so difficult from a technical point of view ?
Thanks a alot again, gino
