Audio GD SA-31 head amp/ preamp . A powerfull Head Amp with Diamond Difference design .
Apr 4, 2015 at 4:45 PM Post #407 of 444
Utopia
I've had the SA31 and currently have a Gustard H10, which is supposed to be very similar ot the V200. I never had the amps side by side, so it's difficult to compare them, but the SA31 definitely had a larger soundstage and sounded a little bit leaner and faster IMO. The H10 is warmer, more intimate, with great tone and musicality, but also a bit closed-in compared to the SA31.
May 31, 2015 at 6:38 PM Post #408 of 444
conquerator2
Los Angeles, CA
The new audio-gd 'budget' amp - http://audio-gd.com/Pro/Headphoneamp/NFB1AMP/NFB1AMPEN.htm
As well as a super budget one - http://audio-gd.com/Pro/Headphoneamp/NFB3AMP/NFB3AMPEN.htm
Jul 5, 2015 at 10:06 PM Post #410 of 444
borrego
I just bought a SA-31SE from audio-gd's France reseller (220V version). With the on going EUR-USD exchange rate, it costs almost the same as buying from audio-gd originally, but including shipping.
I was also considering the C2 11th anniversary edition, but decided to try the last remaining Toshiba BJT diamond differential amp from audio-gd while it can still be found. One might feel regret not doing so as an upcoming amp from another manufacturer with similar topology will cost 110% more to the SA-31SE.
Jul 5, 2015 at 11:13 PM Post #411 of 444
conquerator2
Los Angeles, CA
I was also considering the C2 11th anniversary edition, but decided to try the last remaining Toshiba BJT diamond differential amp from audio-gd while it can still be found. One might feel regret not doing so as an upcoming amp from another manufacturer with similar topology will cost 110% of the SA-31SE.
Good choice! I love mine.
What upcoming amp are you talking about?
Jul 6, 2015 at 12:08 AM Post #412 of 444
borrego
I don't feel like stating the brand/model directly because I was on the waiting list buying that amp. That amp shall be Class A all the way, and with an outboard power supply. It was just the lack of low gain option of that amp turned me away. I do think the relay-based volume control of the SA-31SE will have an edge on channel separation though.
The SA-31SE will be my "power" headphone amp to drive my HE-500, or may be the T1. For all other higher sensitivity headphones I am extremely satisfied with my EPA-007.
Jul 6, 2015 at 12:23 AM Post #413 of 444
conquerator2
Los Angeles, CA
Ok. Only the Cavalli comes to my mind :)
Jul 8, 2015 at 1:16 AM Post #414 of 444
borrego
Jul 10, 2015 at 5:26 AM Post #415 of 444
borrego
Just received my SA-31SE in the office. Surprising, it comes with the optional aluminum remote control. It could the aluminum remote is a standard accessory from the French reseller.
First thing I do is opening up the case and remove all the "Input Short" jumpers behind the input relays. I will be connecting the SA-31SE to my NFB-1 in parallel to the EPA-007 at home. I don't want the input short jumpers to affect my EPA-007.
I am just doing some initial listening with my SR325e in the office. The overall tone is very similar to my 5751 + 832A tube amp. The SA-31SE does resolve better compare to the tube amp. The treble is beautiful, bass is a bit light (but does extend very good). I shall burn in longer period and see if bass will improve.
Overall I am happy with my purchase.
Jul 10, 2015 at 11:14 AM Post #416 of 444
CJG888
Wolfsburg
Try it with the DT48e, if you can find a pair. This is a fantastic combination for jazz and classical.
Jul 12, 2015 at 2:07 PM Post #417 of 444
borrego
A FIX SHOULD BE DONE FOR EVERY SA-31!!!
I have owned the SA-31SE for a few days. While I like its sound, I do find a few problems with my unit:
1. The amp takes a long time to "warm up": I find it needs up to 2 hours to have its sound signature to settle down. And it is with my EPA-007 stacking over it
2. Even after warm up, it sounds lean. The bass and overall dynamic lack quite a bit
I know the SA-31 circuit is base on the discontinued/earlier audio-gd SA100/SA100i/SA200 integration amp. I recall reading something before from audio-gd's Chinese DIY forum saying there is usage of temperature compensation transistors in the SA300 poweramp circuit design (the SA300 is the balanced version of the SA100/SA200). The temperature compensation transistors should be placed/pressed to the headsink shared by the output power transistor.
I start looking at the SA-31 photos on audio-gd websit, and find the SA-31 also has a pair of this temperature compensation transistors (circled yellow below):
Thus I suspect the problems I have the SA-31 is because of improper contact between the temperature compensation transistor and the aluminum back plate heatsink shared with the output power transistors.
I come up with the following "Laundry Clip Fix" for my SA-31: a fix to press the temperature compensation transistor properly against the aluminum back plate. I use all plastic parts to make sure it won't short any circuit by accident.
Step 1: Take out the plastic spings from a pair of laundry clips I have at home (these are laundry clips I bought from Ikea)
Step 2: Find a pair long/sturdy piece of plastics serving as the "pressing levers". I cut off the tails of a pair of plastic forks I have at home.
Step 3: Place all the parts I made to press/clamp the pair of temperature compensation transistors against the aluminum black plate. I apply glue between the plastic clips and the top of the black plate to make sure the clips stay put.
Results after the fix:
1. The amp now only needs about 20mins to "warm up" and have the sound signature stabilized.
2. More bass, and more dynamic sounding signature. My SA-31 finally sounds "properly".
I strongly recommend all SA-31 owners to apply the fix.
Jul 13, 2015 at 10:40 AM Post #418 of 444
Robert777
Thank you for the above post. The information is very useful but it is things like this that may make me return my SA-31SE when I receive it this week.
I was really excited for my new amp but I am now a little apprehensive. I am rubbish with all kinds of DIY and I prefer things to work as intended from the start.
Has anybody else had a similar experience?
Cheers.
