Quick question for R-28 owners using balanced headphones: is the locking mechanism on your 4-pin XLR connector very stiff? Mine seems to get stuck in the ‘open’ position when I connect a balanced cable, and doesn’t spring back into the ‘locked’ position unless I gently force it back into place. It seems to be loosening up a little now with continued use but is still very stiff.
On my friend’s NFB-1, the push tab was very springy and loose, as it should be.
Edit: nevermind, I answered my own question. Seems the connector itself was just screwed in a little too tightly. Loosened the front screws and out it popped. Might just put a very thin spacer between the connector frame and the R-28 case to keep it loose.
