Audio-GD NFB-11.32 & NFB-11 (2014) (Delivery & Impression Thread)!!!
post-10746016
Post #1,366 of 3,013
PurpleAngel
California
California
  I have some extra money thinking of buying an AMP / DAC to attach to the NFB-11. Any suggestions? Is this even necessary / possible? I want to make an upgrade to the NFB 11 and was wondering if I could... Thanks a lot.
You want to buy a DAC/Amp to attach to a NFB-11??  you can't attach a DAC to the NFB-11, as the NFB-11 only comes with a Digital input.
But you also want to upgrade to the NFB-11??
So I'm assuming you looking at buying the NFB-11 and want to option of being able to hook a DAC/Amp to the NFB-11?
I would think the NFB-11 is just fine by itself.
post-10747734
Post #1,369 of 3,013
cel4145
grand rapids, mi
grand rapids, mi
post-10747854
Post #1,370 of 3,013
petezjunior
Just curious if I could attach a higher powered amp to the NFB -11. I want to keep the NFB as a  DAC and connect an amp if that's possible.
post-10747943
Post #1,371 of 3,013
wmedrz
Usa
Usa
Very possible. That's what the fixed rca dac out is for. But with that cash you can go balanced.
post-10747970
Post #1,373 of 3,013
genclaymore
Age
37
I would say the Little dot MK 2 if you can find one cheap on ebay like I did, you might get lucky and get a 2.0 version too. I know amazon some times sell the MK I model which is a hybrid tube-amp, which uses a op-amp and tube. I not good at giving good detail, but I found the MK2 to work every well for me, I haven't had any issues with it, but the manual translations so sub par and even funny at times and I have used it with the NFB15.32 I had before I moved on to this bifrost. There a change you may not like the stock tube's that come with the MK2 but there a chance that you might, If luck is on your side you may find some one selling it with better tubes either in the sell section.
post-10748061
Post #1,375 of 3,013
wmedrz
Usa
Usa
The only tube amp I've ever tried was a speaker amp that was used half a dozen times and has been sitting in storage for over a year now. However, I have been looking at the Project Ember...
From what I understand tube amps, or just the tubes, are really picky in regards to headphones. But that's the advantage of tube rolling.
The question should be not what amp to pair with your dac, rather what amp to pair with your headphone!
If you check the threads for the primary phones you're using I'm sure there will be plenty of good recommendations.
Currently I'm overjoyed with the NFB 11 and DSD/DXD output! What a great and solid product from Audio GD.
Will be looking for more power from that company down the line.
post-10748399
Post #1,376 of 3,013
HeatFan12
  My budget is 500-1000, any more recommendations for a tube amp to pair with the nfb11?
Don't know if I missed it, but what headphones will you be using?
post-10749753
Post #1,378 of 3,013
Douglaster
By the way :
HE500 or HE560 ?
The extra 300$ for the HE560 worth ?
I mean, i can get the HE500 for ~500 used.
post-10749773
Post #1,379 of 3,013
HeatFan12
  he560s
Well, have not listened to the HE-560s (yet).  I have listened to the HE-500s with the 11.32 and I have connected various tube amps to the 11.32 the last couple years.
With that budget and being able to drive various headphones beautifully, I would go with the Mapletree Ear+ HD.
I have connected it to various A-GD gear including the 11.32 and it's a great match.
Cheers!
