Audio-GD NFB-11.32 & NFB-11 (2014) (Delivery & Impression Thread)!!!
post-10723031
Post #1,351 of 3,013
Mamurai
  Starting with the basics:
1 - Are you sure the device is showing normally in the device manager ?
2 - Did you selected it as the default device in the sound reproduction ?
3 - What is the version of the driver in the device manager ?
4 - Youre using wasapi, ASIO or directsound ?
I will post some screenshots for this.
1)
2)
3)
4)
I am using ASIO
So I don't understand why it doesn't work
post-10724146
Post #1,352 of 3,013
Uroboros
Are you trying to play sound from Windows via the USB or are you trying to playing music through an application like foobar2000? Do you get any sound if you test the device through the Windows sound panel (what you included a screen shot of)
I'm running Windows8.1 and I was having issues until I updated to the latest(?) firmware. Now this may not solve your problem; but this is how I use it and you might want to try this to see if it works.
From foobar2000 I send output to the USB. I don't use Asio as the device shows up in the list of output devices. WASAPI (push). Have you tried anything other than ASIO?
Finally as I already have a sound card in my system; I send everything else to is through the sound card's SPDIF port. Since it appears you have other sound devices; have you tried anything like that?
post-10725386
Post #1,353 of 3,013
Mamurai
Thank you so much for your reply. I am away for the weekend but will test it out on Monday.
post-10725453
Post #1,354 of 3,013
cel4145
grand rapids, mi
grand rapids, mi
OK. I think I'm ready to take the plunge into an Audio-GD NFB-11. My path to here has been ODAC (which I like), and then Objective 2, Schiit Asgard 2 and Meier Corda Rock.
* Objective 2--decent sound. Horrible usability with all the connections on the front with the small interface. Got rid of it.
* The Asgard 2--great pre-amp, great sound, hate that it runs so hot all the time. Wish the gain switch were on the front.
* Meir Corda Rock--like the Asgard 2 sound a bit better. Love the small compact size, but really need a pre-amp for my speakers. Hate using my Niles switching box and then a Fostex volume control.
So now I'm ready for an all in one unit, and I can easily fund the NFB-11 by selling off the ODAC, Asgard 2, and Meier Corda Rock . A few questions:
1) My main question is how hot does the NFB-11 run? I'm guessing it can't be as bad as the Asgard 2 which, as full Class A, is running full out all the time when switched on. My home office is warm in the summer, so I really want to get away from an amp that is a heater just when it's turned on doing nothing :)
2) Are most people using the standard transformer or the upgrade?
3) TCXO upgrade seem very helpful for USB? Even Audio-GD describes it as minimal SQ improvement.
Thanks in advance.
post-10725483
Post #1,355 of 3,013
PurpleAngel
California
California
My NFB-15.32 runs warm, but not to the point were I think there might be a heat issue.
The new NFB-11/15 now seem come with air holes, so at least it should run a little cooler then mine.
post-10725490
Post #1,356 of 3,013
conquerator2
Czechia
Czechia
Website
www.youtube.com
Thanks in advance.
1] If it is anything like Compass2, which I assume it is, it gets a bit warm but nowhere near hot
2] I believe the upgrade is free right now!
3\ it is an important part of the DAC. For the relatively small price, I'd certainly take both TCXO upgrades [and I always did so far]
post-10725513
Post #1,357 of 3,013
cel4145
grand rapids, mi
grand rapids, mi
Thanks, guys!
Sounds like it would be an improvement on the Asgard 2 desktop heater :)
Didn't know about the transformer upgrade. That's great.
I just sent them an email for a price/shipping quote with the TCXO upgrade included.
post-10725539
Post #1,358 of 3,013
Douglaster
Thanks in advance.
1 - The unit after all day listening to it is warm to the touch (33C accordingly with the laser thermometer). This new unit with the 3 vent opening is really good for ventilation.
2 - Normal transformer here.
3 - Yep, even them said the improvement is marginal. I will someday get it thought.
post-10725662
Post #1,359 of 3,013
Douglaster
Another thing to fix ! To VIA and King wa.
 - Youtube videos, on both HTML5 and Flash formats dont work in 384khz !
Thanks.
post-10725865
Post #1,360 of 3,013
cel4145
grand rapids, mi
grand rapids, mi
Thanks. Warm to the touch is OK and to be expected :)
So now I just have to wait for them to give me a quote so I can make my payment and order.
post-10728097
Post #1,362 of 3,013
Douglaster
  The over 192K support only by the KS and ASIO.
You want to check if working with either mode.
Oh i see.
The good news is that many games work OK with the 384khz.
I played Outlast yesterday and man, it was difficult to not **** myself with the scary sounds, respirations thru doors.
Really scary.
post-10731340
Post #1,363 of 3,013
Mamurai
I don't get any sound, no.
I also have a problem that my audio device manager stops responding or is very slow whenever I have the unit plugged in and powered up.
Finally I disabled all other audio devices and uninstalled other audio drivers which could be conflicting, but without any results. I am very confused why the same driver and device works fine on another setup using windows 7 ultimate as this PC.
post-10743120
Post #1,364 of 3,013
wmedrz
Usa
Usa
How do you stop this popping when listening to DSD! AHHHHHHHH!!!!!!!!!!!!!!
Edit: I was able to stop the popping noise! For anyone who has popping noise when switching between pcm & dsd modify your pcm/dsd transition to 50-100 milliseconds. No more pop!
post-10745798
Post #1,365 of 3,013
petezjunior
I have some extra money thinking of buying an AMP / DAC to attach to the NFB-11. Any suggestions? Is this even necessary / possible? I want to make an upgrade to the NFB 11 and was wondering if I could... Thanks a lot.
