Audio-GD NFB-11.32 & NFB-11 (2014) (Delivery & Impression Thread)!!!
post-11246996
Post #1,621 of 3,019
willowbrook
  Hi. I'm currently looking for my first full-sized amp/dac solution and these got in my radar. What is the difference between NFB-11 and NFB-11.32?
I'm guessing DSD,DXD support, 384K playback capability, can upgrade transformer to 35W?
You might be better off sending an e-mail to them for specifics.
post-11247345
Post #1,622 of 3,019
JustinZ
Just ordered my NFB-11
2x TCXO
Came to $525CAD with our now ****ty exchange rate
This will be my first DAC or AMP, hoping this will be my endgame unit along with my also hopefully endgame HD-650s
Upgrading from HD-555s and M50s
post-11248062
Post #1,623 of 3,019
teofilrocks
Another contact and Kingwa has said that a new firmware is coming out soon to fix the problem.
Hmm, so one day the solution they have is to cut a wire inside, and the next it's to wait for a firmware update? That makes me a little nervous buying, especially when you add in all the comments in Audio-GD threads about driver difficulty.
post-11248088
Post #1,624 of 3,019
willowbrook
2x TCXO
Oh wow, I just notice the exchange rate for canadian dollar changed substantially. That is some crazy change.
post-11248092
Post #1,625 of 3,019
willowbrook
The product itself is great...the problem is only related to WASAPI. I will try ASIO when HD600 gets here...
post-11248129
Post #1,626 of 3,019
teofilrocks
Ah, ok. I'm really not familiar with WASAPI and ASIO. I use iTunes and Spotify, not Foobar or JRiver, since I'm not into high-res audio files. So I'm guessing neither of those drivers would apply to me?
post-11248172
Post #1,627 of 3,019
willowbrook
Installing driver is very easy and it works well. Also, if you use iTunes and Spotify, there are going to be no problems. Same with other softwares that use directsound.
post-11248190
Post #1,628 of 3,019
SpirosG
WASAPI, by itself doesn't have this kind of behaviour ...
I read that you use VLC ... Have you tried foobar ?
post-11248205
Post #1,629 of 3,019
willowbrook
I am talking about wasapi on foobar2k...I can't get anything to work on VLC except for DS. I just installed the post/pre-track silence component that you suggested, this might be a temp fix for now.
post-11248207
Post #1,630 of 3,019
teofilrocks
I could also try using optical first, since I'm on an iMac running BootCamp. No drivers needed. Should be no audio gap.
post-11248218
Post #1,632 of 3,019
conquerator2
Czechia
Czechia
Website
www.youtube.com
Actually, my Audio-gd related problems were always due to the ASIO drivers, I believe, which then crippled WASAPI as well... Or rather the crappy VIA drivers, which are the native ASIO drivers...
I hope I was just unlucky, as these issues don't seem too common to begin with.
post-11248377
Post #1,633 of 3,019
Surlias
The drivers were easy to install. I haven't tried WASAPI, but Direct Sound seems to work ok. The only issue for me really is how it takes a second to start outputting sound after initiating playback, and sometimes when switching tracks or albums or whatever. I definitely have the issue even with playback in apps like VLC, which Willowbrook says he doesn't. Seems like everyone has a slightly different experience.
post-11248417
Post #1,634 of 3,019
willowbrook
Hmm..I just tried pausing and playing movies in VLC. I use Foobar2k for music playback.
post-11248433
Post #1,635 of 3,019
teofilrocks
  I haven't heard the NFB-11 but I wasn't crazy about the HD650 out of the NFB-15.  Until I plugged it into my Project Ember, that is...
What was it about the NFB-15 combo you didn't like? What did you like more about the Project Ember? I'm on the fence between the NFB-11 and NFB-15, and I'm not sure which would be better for my HD650 and soon-to-arrive TH600. Open to other options like a Project Ember and Modi or something in a similar price range.
