JaMo
- Feb 8, 2011
I'm looking for a slightly neutral DAC/amp to pair with my K712 pros.
Here, in France, R2R 11 is 40€ cheaper than NFB 11.28 (369€ vs 409€, inc taxes). The opposite on Agd website where 11.28 is 20$ less!
I can't make my choice... The seller says 11.28 will be a better option for my K712. But, on the other hand, I'm really tempted by R2R 11 for try something different than usual Sabre chip!
Is the R2R 11 is neutral/uncoloured enough for a neutral combo with my K712?
Anyone compared these to the idsd Black Label?
Looks like a different transistor was chosen, otherwise, same circuit. Probably equivalent.
While the positioning is quite similar, the components used on the amp section are different from R2R to NFB. Specs of the headphone amp are similar. Any idea why?
I think i'm sold with the R2R11 or NFB11.28.. Will contact Kingwa. Thanks guys!
Straight from the r2r summary lower down on its AGD page...
" Option to set Neutral or Warm sound (Jumper setting) according to personal taste."
Hey bud. I'm seriously considering the R2R-11 and wanted to pick your brain a bit about these pops.I'm testing the R2R 11 at this very moment (went set to neutral).
The option "neutral or warmer" by switching jumpers exists for a long while even with their warmer sources. That doesn't mean the sound will be neutral, just less warm in this case. Or warmer in the case of NFB 11.28, but not as warm as their other solutions using PCM1794.
By the way, the R2R is very good, but it stills colored, some kind of tube/analogue signature but faster. The pops when switching songs or open an app on Windows bothers me, thought.
Awesome! One step closer to paying. I've had the Audio-GD email sitting in my inbox for a few hours and needed a little push. Thank you for your time and reply!No pops through coax / optical here. Only from USB when changing sample rates
Haha, you're welcome. Though I might reiterate here; I do get occasional pops through USB but I pinned it to my slower drive. It definitely stabilized over time if it was doe to the Anamero, but coaxial / optical remained pop free regardless. And regardless indeed, you would not regret buying this unit. It is a steal IMO.Awesome! One step closer to paying. I've had the Audio-GD email sitting in my inbox for a few hours and needed a little push. Thank you for your time and reply!
