Richyieee
- Apr 10, 2012
Hi Greed , very interested in your stratus vs master9 opinion
The LCD-X/M9 pairing was very nice to my ears. The synergy between the two headphones exhibited well controlled bass, good texture, and decent slam although it could be tighter (maybe the GS-X mk2 is a better match just like with the LCD-3). I find the Audeze headphones tend to pair well with SS amps that have plenty of low-end and good bass control. I also found the LCD-X to gain some air and increased soundstage with the M9 that definitely helped. I feel the LCD-X could stand some improvement in those areas.
Based on everything I've read, I think I'm ready to commit to the M9 to pair with my LCD-X. My only question now is about with which source to complete the chain.
Both you and senson mentioned that the X lacked some aggression / bass slam/tightness perhaps due in part to your sources (DA8 / DP-777). Are there any suggestions anyone has for a DAC in the $800-$1200 range that may help round out those issues and complete the chain with M9 and LCD-X?
(I've been considering Gungnir, X-Sabre, and DA8)
Edit: In terms of bass, one of the best I've heard is the PWD MK II. If that is at all possible, you will not be disappointed.
I've recently been reading about the network bridge bought separately. What is it capable of, and is it something I need if I intended to run MK2 through usb?
Using the HE-500 with the M9 would I use High or Low power mode?
