maguire
- Dec 28, 2007
oh I think where all curious don't worry about that .........
How about the driver issues with USB. Did Kingwa say anything about that?
I know he was working with who ever developed the driver. What was the out come?
Just FYI, Kingwa has updated the Master-7 product page to specify the i2S interface. Seems not compatible with the Off-Ramp RJ-45 output...
I'm no I2S expert but isnt it all about ensuring that the voltage is compatible, ie: 3.3v out from the source and also the pins line up from the source RJ-45 connectors?
I suspect (correct me if i'm wrong) that a custom RJ-45 cable should work with this pin layout, assuming that the Offramp puts out 3.3v's from its I2S output?
I2S Rj-45 output (offramp) Master 7 I2S Rj-45 input
Pin 1 - SCLK Pin 1 - SDATA
Pin 2 - SCLK return Pin 2 - SDATA return (ground)
Pin 3 - SDATA Pin 3 - L/RCLK
Pin 4 - SDATA return Pin 4 - L/RCLK return (ground)
Pin 5 - L/RCLK Pin 5 - SCLK
Pin 6 - L/RCLK return Pin 6 - SCLK return (ground)
Pin 7 - MCLK Pin 7 - MCLK
Pin 8 - MCLK return Pin 8 - MCLK return (ground)
So, wire from Pin 1 (offramp) needs to connect to wire from Pin 5 (Master7) as an example?
Otherwise, hoping that Kingwa will release a source player that will have an I2S output that is compatible with the source input (4) on the Master7? If not, then users will probably have to make a custom RJ-45 cable and find a suitable source that outputs 3.3v's?
Customers if want especial configure of the I2S input is easy change before shipping, we just want to change the inside wires connect , this is also easy change by users within few minutes without soldering .
The level compatible from 3.3 .
