Audio-Gd Master 7 - Discrete Fully Balanced DAC (PCM1704)
Aug 4, 2015 at 2:22 AM Post #2,973 of 4,318
drez
Server 2012 r2 (12 services active)3.3v rail separate linear powered,usb signal direct from pci slot,............
sound extreme detailed,organic,deep, but not wide,no 3d feeling,middle section missing. Listen one hour,im bored.
Hmm so u like your SD card transport better?  I have been wanting to try one of those.  I have already sunk a lot of money into computer though - but turning computer into hifi source is uphill battle.
Aug 4, 2015 at 8:02 AM Post #2,975 of 4,318
r one
just a bit too earlier Flosa !
Aug 9, 2015 at 2:27 AM Post #2,977 of 4,318
ccschua
has anyone tried using other type of fuse ? is it 5mm x 20mm ?
Aug 9, 2015 at 3:45 AM Post #2,978 of 4,318
Articnoise
Sweden
No volume control and no changeable fuses.
Aug 9, 2015 at 4:14 AM Post #2,979 of 4,318
Fukuoka, Japan
The fuses are built into the transformers, so they can't be changed.
  Does anyone bypass the Dsp-1?
I use RME Madi-fx as the digital interface and use AES to connect M7.
I think if I bypass Dsp-1, I can get more detail than default setting.
What do you mean by bypass? You could do the up-sampling on a computer with iZotope or similar (built into some audiophile players, such as Audirvana in OSX) or do you mean physically bypassing it?
Aug 9, 2015 at 8:30 PM Post #2,980 of 4,318
motberg
I have kind of the same question, I think...
Is anyone using HQPlayer for the up-sampling to the native M7 optimum (I assume 32bit / 192 Kz ?) and then using jumpers on the M7 to disable the internal up-sampling?
Thanks....
Aug 9, 2015 at 11:50 PM Post #2,982 of 4,318
evillamer
Thanks....
Instructions are in chinese, but the pictures should explain it:
http://bbs.audio-gd.com/dispbbs.asp?boardid=2&Id=28537
Aug 10, 2015 at 8:44 AM Post #2,983 of 4,318
Does master 7 has a volume control? Thanks.
When ordering M7 or NFB7 you can ask Kingwa for volume control option. It's in IV and no SQ degrade.
It costs only $100 including an aluminium IR volume control unit.
