Thanks! Just ordered the blaster.
My M11 is factory setting, do I need to do anything to special to prepare for the update, except installing the software, connecting the blaster, and booking a TeamViewer appointment?
Yea, I'd like to know this as well. I've got a Blaster, just need to know the steps, etc...
http://audio-gd.com/Master/Master-7_384/DSPupdataEN.htm
Just make sure you have the 12.1 version of Quartus which can be found here: https://www.altera.com/downloads/software/prog-software/121.html
That is a standalone version which is all you need. Otherwise you will end up downloading some version that is a couple gigabytes which is not necessary.
Once the software is installed, you want to make sure you install the drivers that come with it so that your USB blaster is using these drivers. You can do this by selecting the USB blaster in Device Manager, updating the device drivers, and pointing Windows to the Quartus drivers folder (C:\Program Files\qprogrammer\drivers) or wherever that you installed the programmer to.
Contact Audio-gd and schedule a time. Those times listed on the website are not the only times available apparently (which is good because those posted times end up being in the middle of the night for most people). Kingwa stated that other times are available:
If the time is during your sleep time, send email to inform us, date a earlier time, maybe 2100 to 2400 in your country.
Our worktime is 0800-1200, 1330-1730,1900-2200.
Once your time is scheduled, just have everything ready to go 15 minutes early.
Prior to the whole process you may want to give your computer a fresh restart just in case and have background programs closed. Empty your recycle bin. These are all just precautions, probably not absolutely necessary.
1. Turn off Master 11 before attaching the blaster to it! Otherwise you may damage your DAC.
2. After Master 11 is turned off and blaster has been attached and connected to your computer, you can turn the DAC back on. The main thing is just don't push/pull the connector while Master 11 is on.
3. Once DAC is back on, you can open up the Quartus programming software and have it ready. Open the TeamViewer software which is going to give you your Teamviewer ID and a password that is usually randomly generated everytime you start the program.
4. Audio-gd will contact you around your appointment time and ask for your Teamviewer ID and password.
5. Once you send it, you should see Audio-gd take control of your computer shortly afterwards (message pops up in bottom right corner telling you someone is connected to your computer and your wallpaper might turn red.
6. At this point Audio-gd transfers their firmware file to your computer and uses the Quartus programmer to install it to the M11. You can just sit back and watch. After the process is successful, Audio-gd will delete the file that they transferred to your computer and then delete it from your Recycle Bin. You probably want to make sure nothing important is in your trash bin in case the agent hits Empty recycle bin
7. After firmware has been deleted from your computer, Audio-gd will disconnect the Teamviewer session and you are good to go!
8. Turn off your Master 11, remove the USB blaster, turn Master 11 back on and enjoy!
