Rockin_Zombie
Fellow m11 owners, question: if I have devices connected both the rca out and XLR out of the preamp, does the output power from preamp get halved, or are they independent of each other?
So I notice Audio GD updated the site and it now has firmware upgrade information http://www.audio-gd.com/Master/Master-7_384/DSPupdataEN.htm . So the site has updating instructions for online version but maybe the other method is better. The USB Soundblaster must be purchased for updating manually after AGD releases the firmware? Also is there a english version of Quartus
I am trying to install the I2S HDMI module on my Master 11 - seems simple enough.
The electrical socket for the I2S is glued and very difficult to remove from the board.
I do not want to break anything - does anyone have suggestions or experience with this? I had thought that it would just unplug and then I could plug in the new socket.
Thanks for any help.
Bimmer,
I got th plug out no problem - thanks for th tips.
Is there any secret as to how to solder the 3.3v wir?
The spot that I am supposed to solder in is right between the 2 sockets and is mostly covered up by on of them. No access to get the tip of my solder iron at it.
Any suggestions?
