jimmychan
- Jun 26, 2009
Does any body has Susvara drive by HE9? How does it match? Does it has enough power for it?
Thanks,
Thanks,
Yes, it smoother without loosing resolution, on the contrary. Never heard better for sure.first impression "no harsh anymore" like it was written in product description. I was thinking where is harsh on HE9 but now I hear much more listenable analog sound, it's really great!
absolutely awesomeYes, it smoother without loosing resolution, on the contrary.never heard better for sure.
I had now similar experience with EF400. I did not like the unit from the beginning. Now after 1st month I would swear, the sound is better, the soundstage is opening. And I am sure, it is not brain psychoacoustic as I am often comparing it to my other amps. And I had similar experience with Audio-gd R2R 11 and C2 in the past.Funny but i am not surprised: last week, the he9 mkii had lost most staging abilities. They are now coming back. It is surprising, after 6 weeks of burn-in.
The unit has been brillant at times but is not cooked yet. I know it can do more. It's been very good for the last two days. But not brillant. Nearly excellent but not quite.
Being a no feedback design is likely the reason for such slow burn-in..
But the ultimate slow burn-in is with the Master series power amplifier. My own m3 took 3-4 month to wake up. If you don't belelieve in burn-in, and you want to stick to that position, buy something else.
The mkii is getting there. It is amost there in fact.
Audio-gd is known for long burn-in. The r2r-11 mkii is one of the quickest, but still takes 500h. The Master-3 takes a solid 4-6 months.I had now similar experience with EF400. I did not like the unit from the beginning. Now after 1st month I would swear, the sound is better, the soundstage is opening. And I am sure, it is not brain psychoacoustic as I am often comparing it to my other amps. And I had similar experience with Audio-gd R2R 11 and C2 in the past.
Just received mine. Your above definition is the most accurate one.. Even my old R28 (the DAC part of it) sounds amazing through HE9 Mk2 (and I only started to burn it in..). Very happy with the tonality! It is neutral yet musical and natural sounding.. I know many find it difficult to associate the three definitions with one device, but I would still state it this way.Yes, it smoother without loosing resolution, on the contrary. Never heard better for sure.
You mean 4-6 months of music playing or just when it is powered on?Audio-gd is known for long burn-in. The r2r-11 mkii is one of the quickest, but still takes 500h. The Master-3 takes a solid 4-6 months.
Does the idea of listening to music for 4-6 months sound unpleasantYou mean 4-6 months of music playing or just when it is powered on?
No, but it is just about 4320 hours. And I believe in burn-in, but I am quite sceptical about this amount of time, even that someone will remember the sound of the unit from 6 months ago and then will be able to compare to the actual one.Does the idea of listening to music for 4-6 months sound unpleasant
Playing music for the r2r 11.mki, a mix of the two for the Master-3, in my case, 5-6h a day. I think 3-4month should do it with normal use.You mean 4-6 months of music playing or just when it is powered on?
I don't know but I would trust @FredA on this. He has a lot of experience with Audio-gd gear. And of course it's just to give you some expectations. Eventually you will burn it in whether it needs it or not. So my approach is just enjoy it and expect some ups and downs and that it will not show you all it has to give for a while yetNo, but it is just about 4320 hours. And I believe in burn-in, but I am quite sceptical about this amount of time, even that someone will remember the sound of the unit from 6 months ago and then will be able to compare to the actual one.
