jimmychan
- Jun 26, 2009
I have been very upset that the SBT-EDO could not work with the DI-V3 in Async mode. My purpose to buy the DI-V3 is because the Async mode is superior than the Adaptive mode.
Thanks for the review, I'm thinking about ordering one also. Regarding brightness I read firmware #5 provides additional warmth without sacrificing resolution have you heard anything about it? I am hoping for a nice plug and play setup with my MBP / pure music. All the tech talk about drivers&firmware is making me nerves!!
How would you compare it to the JK mk 3?
Strangely, the async mode is reported to work on the SBT compatibility sheet.
My async firmware basically gave me stuttering sound but I managed to have it working correctly once. Never could get it working after that.
The Resonessence Labs Concero does not work with the SBT either. I suspect the SBT is not fully compliant, that's why I moved on and bought a small laptop with JRiver to avoid such issue in the future.
Even with the same firmware #3 (reported as adaptive on the SBT), it sounds much better on JRiver than on the Squeezebox.
Does it work with JRiver in async mode (firmware #4)?
If it does, what settings are you using?
I've tried it with Windows7 64bit and JRiver (but without JPLAY), with firmware #4 it worked wery good, also decided to buy laptop and sell SBT - BUT DI-V3 will not accept JPlay. So I'm confused Probably will buy laptop to work as dedicated music server - as described here http://www.genesisloudspeakers.com/newsletter/Newsletter_10th_Anniv.pdf , eventually will accept JRiver + Jplay without Extreeme Engine as DI-V3 does not support low buffer value
Clemmaster, how could you describe differences in sound between SBT and laptop with JRiver? What laptop is it, I mean what CPU? Atom based with passive coolant?
I didn't try it yet (NFB-27).
I have an issue with the 1.22 drivers on my new laptop (win8 64bits): I simply can't install them.
It says: "one or several modules could not be installed" at the very end. The whole drivers are that module... I can't seem to find the old 1.1 drivers on Audio-GD website.
I'll check on my mom's laptop on which I managed to install the old drivers (win7 64bits) if I find the installer. I'm using this laptop for now...
Here is the link to the 1.1 drivers:
http://www.audio-gd.com/Audio-gdUSB32forwindows384.rar
As for uninstalling the 1.22 drivers, make sure you're still using the correct firmware and your DAC is switched on.
Green Is adaptive Firmware (#5 I think) Black is async (#4 as shipped),
#4 was too bright and agressive in my system. #5 by contrast is warmer and was sonically spot on - it really was that moment when I had finally found the sound I'd been searching for.
I don't know about firmware #5 (I haven't got it), but the #3 needs drivers 1.1 (although I've managed to get them working with the 1.22).
I've used the #3 for a while and the sound was warmer, but in the end I went back to #4 and I think is lovely. Actually, when I switched back to #4 I thought it wasn't brighter than #3...sometimes we rely on our memory, and we're wrong
^ Good! It's what I meant with "make sure you're still using the correct firmware and your DAC is switched on" but my English is broken
