DACLadder
- Feb 16, 2013
@jimmychan Did you get your DI20HEs to work OK with Gustard's 10M clock source? You mentioned that you had trouble a long time ago with the first HE. Thanks!
My unit has 2 sine outputs, plus one square one so it can feed 2-3 gears. It needs a 5.5/2.1 connector. I prefer the sine over the square out with it.Can one OXCO clock be used to clock both the DI-20HE and the R-7HE?
What type of termination is needed for the power input? Is it a a 5.5mm standard barrel?
If I could have one clock and one LPS to power both clocks that would save a lot of money.....
Hi Dacladder,
This is one of the LPSU's that is use in my Audio setup. It's a 200W HDPlex and as you can see it has the ability to dial-in variable outputs for A and B. I use this for JCAT USB and Ext 10M clocks. It comes with the output cables. Also have 2 x 100W HDPlex one for each CPC and APC.
It is stated in the di20's manual that as long as the sensitivity is as needed and the input is 75 ohms, it will works better than the same cable using a voltage output. The needed sensitivity is 0.5VPP, which is the standard value, i presume.Does the DI-20 ACSS BNC output work when connected to a BNC input on a non-Audio-gd DAC? If it does work, will the audio quality be better than using an RCA S/PDIF cable with the non-Audio-gd DAC?
