Audio GD has presented a couple of new products today, I think, the Compass 384 and NFB 3 (384), with the PCM5102 DAC chip. Does anyone know any other products that use this chip? How does it compare to Wolfson or Sabre DACs?
JKDAC32 and the new Ciunas. Also many of Meridian digital line (the most current one being the explorer). Arcam did a really good dac (rPac) with XMOS + PCM5012 too. Generally chip doesn't mean squat. The Meridian Explorer and the JKdac32 for example, have little to nothing similar the sonic department.
The main advantage of PCM5102 is that it accepts 32bit/384khz signal, while Wolfson 8741 can only accept up to 24/192. Sabre (ess9018) can also accept 32/384, but is expensive to implement well. To add something technical, the 5012 is a voltage output dac, so it doesn't need an i/v stage, and thus can save some cost too (and invest that in something else).
I could imagine how it will sound, but I'll refrain from speculating on gears that I haven't heard.
