http://www.audio-gd.com/Pro/dac/Amanero/AmaneroEN.htm
Output Format :
I2S 32bit or DSD64,DSD128 (Native mode and DOP mode) - On Windows DSD256,DSD512 too
Supported systems:
NO Drivers needed for Mac OSX 10.6+ and Linux with UAC2 compliant kernel.
KS/Wasapi/WDM/ASIO Drivers for MS OS XP to Win10 32-64bit included at no fee.
Apple ISO (Iphone and Ipad through camera kit )
Andriod (Support USB2.0)
Please note:
(176.4kHz, 192kHz, 352kHz,384kHz and DSD are only available in USB audio class 2.0 and 3.0 / High speed mode . USB audio class 1.0 / 1.1 support up to 96K /24bit )
The Amanero had very low jitter present. From the HiFiDuino report, the Phase Jitter 0.04~2.41ps (10Hz~1MHz), Total Phase Jitter (RMS) 2.42ps
Please note:
1, If you want to buy the Amanero Combo 384 replace the USB32 in our E9018 built-in and DSD support products (since 2014, Aug. ), you want to buy the new MCU at the same time .
2, If you want to buy the Amanero Combo384 for our PCM1704 built in DAC, you need buy the new MCU replace in the unit for the better performance improve .
3, Send your unit series number to us while you place the order.
4, If the module for non- audio-gd products, just buy the standard version.
5, If you want custom order different function of the MCU, you can buy the K150 program and don't want buy the MCU
http://www.audio-gd.com/Pro/dac/Xmos/XmosEN.htm
Supported Sample Rates :
44.1Khz 48Khz 88.2Khz 96Khz 176.4Khz 192Khz 352.8Khz 384Khz
Output Format :
I2S 32bit or DSD64,DSD128 ( DOP mode)
Supported systems:
Please note:
Are there any users are already those who use and successfully installed these modules?
I have a problem with support dsd128 (and clatter when start playback dsd64) on my DAC AUDIO-GD NFB-1SE 2014 VER (both linux and Windows (may be weak quartz "TCXO upgrade 12,000 Mhz" for USB) and I would like to update to AMANERO! Do not quite understand what it means "to need buy the new MCU replace"!
Kingva also said in the letter that
"The NFB1S replace the Amanero want to edit the MCU software but we have not the unit for test."
Let's talk and try understand the subtleties and nuances of this new solution!
