I nearly didn't buy the Penrose after reading through this thread, but research led me to get them anyway because I couldn't find another headset that did what I was looking for (PS5 wireless support, great sound + 3.5mm jack connection for video calls on my Mac - so I don't have to keep moving the usb stick).
Slightly at odds with many people on this thread I've found the Penrose to be just what I was looking for. I don't seem to get any of the pops and clicks reported by others. The only time I've noticed issues is when I had the USB stick plugged into the rear port of my Digital Edition PS5 and that was just a brief pop/click before going back to great sound.
I'm not sure if this is part of the reason mine works so well, but my PS5 is using wired ethernet - that might help with the interference?
I've had no issues with using the front USB port, but I'm now using the back port with an extension cable because it looks neater. Since I did this I've had absolutely zero problems. I'm sat about 3 metres away from my console, and although the wireless range is fairly short I don't usually walk away from the sofa when I'm playing games so it doesn't affect my usage at all.
The only negatives I've really found with the Penrose:
1. The volume wheel really does move in big steps and due to this I find it very difficult to use and usually end up adjusting volume on the device. For me this is the number one issue because at the moment it's a fairly trivial fault, but it is
really annoying to use.
2. I've used the headset wirelessly with my MacBook, and as someone else reported earlier in the thread, if you turn the headset off when the USB stick is connected to a MacBook it can be really difficult to get it to connect again. It seems like the MacBook USB interface goes to sleep and it doesn't usually wake up again (even if you unplug and replug the dongle). I mainly use it with a wire on my MacBook so this doesn't bother me too much. Would be great to get this fixed though because it is easy to repeat the issue.
So for me and what I was looking for I'm *really* happy with my Penrose.
They sound absolutely fantastic - to the point where (unexpectedly) I'll choose to use them to listen to music over Bluetooth in preference to my Bose QC35s and AirPod Pros because they sound
so much better. Admittedly, I'm not an audiophile - I gave up on wired headphones a while ago for music so I'm only comparing against other Bluetooth headphones.
I also find them very comfortable - especially considering they weigh more than my other headphones - and I have a bald head so limited padding.
On PS5 they're basically plug and play. I just turn them on and they connect and re-route the sound automatically so I can easily switch between headphones and my home theatre. It's also really easy to switch between wireless, bluetooth and Aux with a single button press so I can seamlessly move between Bluetooth on my iPad, Aux on my MacBook and wireless on the PS5. This works much better than I expected it to.
My main reason for posting this is to make sure that people are aware that there is a great product here. Yes, it does sound like there's some teething problems at the moment (hardware issues, and some immature software), but if these can get worked out then I think the Penrose has a huge amount going for it.
