Combover Grover
ya but they were asking about PS5PC does too, at least for games that support it. There are also other 3rd party software that do similar things.
Thanks guys, I will try it out. On a side note, if I bought the suede dekoni ear pads, will they fit ok without the plastic clips? I cannot find the Mobius gel pads anywhere and it appears they are discontinued. These pads just do not cut it for me unfortunately and I cant believe they would use a proprietary ear pad.Pretty sure the audio format option on the PS5 (PCM, Dolby, DTS) only has to do with the HDMI audio out, and not headphones. This was addressed a while back in this thread but it’s been a bit so can’t remember how far back. Most games don’t seem to support 3D audio so I just play with it turned off (except for on games like Spider-Man and GoW where I know for sure it’s supported), and the soundscape on the the Penrose is still great for determining what direction sounds are coming from.
Before I return the Penrose, I would like to give it two more solid nights. Does anyone have any EQ settings for competitive Call of duty. Right now there is way too much bass.
Thats what I am currently using as I found them online. With the volume at max, there is so much bass during explosions my headset literally vibrates/rumbles. I would prefer no bassI don’t play CoD but I’ve been very happy with this EQ setting across all games and music: 0, -1, -1, -3, -3, -3, -2, -1, 0, 0
LOL yes, I know my wife cant believe I play at that volume but I do.Ah gotcha. My weak ears can’t handle these at full volume, so I haven’t run into that issue. I’m wondering, do you have the headphone volume setting on the PS5 set to max? That was recommended by Audeze to get the best quality sound as well.
Does anyone know when additional Penrose X orders are expected to be fulfilled?
Think about it the other way: you haven't damaged your hearing to the point where you have to listen to the headphones at max volume in order to hear it.Ah gotcha. My weak ears can’t handle these at full volume, so I haven’t run into that issue. I’m wondering, do you have the headphone volume setting on the PS5 set to max? That was recommended by Audeze to get the best quality sound as well.
