X-Frame
- Mar 7, 2015
I feel you. I probably would be driven up the wall if I had to listen to the Mixamp 5.8 or Mixamp 2013 hiss by itself.
The hiss on the Mobius is less in volume so I don't think it'd bother me if it's the only thing that played, but then again I'm used to having a fan on constantly or the fan noise from my PC, alongside the AC unit, so my tolerance for background noise is probably higher than others.
I have whatever the most current PS4 Mixamp Pro TR. Is that supposed to have any hiss? I don’t use the Dolby SS though. I don’t personally like what surround sound does to the treble and bass so I leave it off. Otherwise I am using Philips X2’s (Open) as my main headphones. If there is any hiss, I never noticed it.
Either way, add me to the camp that would be completely fine with Audeze delaying my shipment until they looked into this, if it does become something that they deem worthy to delay and look to fix.
