Hi I just got myself the Mobius and I have a few questions and some concerns.
1. I have some major microphonics sounds from the USB-A to USB-C. I think this is the worst cable I ever seen coming with an expensive headset. Also its super stiff. Would switching cable solve my issue? Anyone that could maybe point me in a good direction for a replacement cable that also allows the headset to charge? Also I know you can use like a clipper or something, but.. I don't really like that solution and its not perfect. Are there any other ways to tackle this problem?
2. When I have my headset on, I get electric white noise sounds while I'm holding my smartphone with its charger connected (to the wall). Is that normal? I never had this issue before on any previous headsets. Could that damage my phone/headset?
3. I have a constant, very slight white noise sound in the background. Once you hear it, you cant unhear it.. It bothers me. I assume there is no solution for this since I already have the latest Firmware/Software.
4. Anyone have a EQ profile that is good for FPS games (for APO/PEACE)? Games like PUBG/COD/OW/CSGO/VALORANT. I feel like there is way to much bass using the default "Footsteps" preset, or any of the others for that matter. I cant hear any footsteps when bombs and nades goes off all over the place.
5. Any way to let Discord run stereo while running games with 3D/7.1?
6. Why is the led blinking blue once every few seconds? Is that normal or what does that indicate?
