Mani ATH 87
In 7.1 3D off mode, does it still ignore the LFE channel?
I'm not sure what you are asking. Are you saying that when you turn 3D off there's no bass in the Mobius?
The main 7 channels are full-range, but any sound specifically played through the LFE channel is silent. If I switch 3D on, the LFE channel is audible.I'm not sure what you are asking. Are you saying that when you turn 3D off there's no bass in the Mobius?
Yes you get all the channels but with 3d off, you are down-mixing to 2 ch, so there will not be any surround or ambiance.In 7.1 3D off mode, does it still ignore the LFE channel?
Mine doesn't playback the LFE channel when 3D is off. I'm trying the "Test" function in Windows on the playback device and the LFE is silent. I also tried a 7.1 test tone video and the LFE is silent with 3D off.Yes you get all the channels but with 3d off, you are down-mixing to 2 ch, so there will not be any surround or ambiance.
Shouldn't the LFE channel also be mixed in? I remember reading that the Dolby spec recommends the LFE channel be simply dropped when downmixing to stereo, but most content lacks bass without it. Practically every player's downmixer includes the LFE channel.Yes you get all the channels but with 3d off, you are down-mixing to 2 ch, so there will not be any surround or ambiance.
Yes all channels including LFE will be downmixed, none of them are dropped.Shouldn't the LFE channel also be mixed in? I remember reading that the Dolby spec recommends the LFE channel be simply dropped when downmixing to stereo, but most content lacks bass without it. Practically every player's downmixer includes the LFE channel.
In my case the LFE is definitely dropped with 3D off. I've tried both WASAPI shared mode and exclusive mode, and the LFE is dropped in both cases. The moment I switch on 3D I can hear the LFE again, in the middle of the audio stream.Yes all channels including LFE will be downmixed, none of them are dropped.
Listen for the LFE channel using the Windows "Test" function on the 8ch playback device. Media isn't a good test since the bass can overlap with the other channels. You could also use some 7.1 speaker test tone videos which don't overlap the LFE with the mains.I'm not noticing any lack of bass with 3D off, just doing some testing now since you asked.
Bad contacts/cable may explain the charging and also issue with USB 7.1 mode. Is it possible to try a different USB cable? I assume you have already tried a different port.
The ultra thin driver used in Mobius will move when there is a change in seal/pressure. So it is normal to crinkle if you push against the ear cup.
Are these primarily for gaming and films or do they also satisfy music listeners?
