jibzilla
- Mar 27, 2013
Yeah... no, just stop.
You should probably say "LCD2 pads don't work for me" instead of just saying they suck if it's the case.
Yes I know that. But some headphones benefit more from being balanced and the 3's to me benefited allot better to me than the 2's or he-500's. Seeing the X's coming with only se is just sort of a bummer to me and leaves me wondering if it will greatly benefit from being balanced like the 3's or kind have a give and take scenario that I had with the 2's and 500's.
For people that have no use of their hands going balanced may not be a cheap decision. Unless they want to go with a cheap adapter cable which to me would be frustrating on a headphone that costs as much as the X's do. Just my 2 cents.
Hi Guys,
This is my first post and as a Audeze dealer in the UK this is the first I have heard about the LCD-X and XC, as a LCD-3 user I can't wait to get a chance to hear these, any idea on release? be interesting to see where the prices will sit in the UK.
Think I need to send a quick mail over to the Audeze Distributor over here to see what he knows
on paper, seem to me the easiest audeze to drive
It looks like that. I wonder how that'll translate to amp compatibility? I'm running my LCD-2s out of a Mjolnir and I've yet to hear a less expensive amp I like with them. Doesn't mean they're not out there, but I haven't found anything yet. I also have a Magni (used for my HD650s at work) and although it's able to power the LCD-2s, I find the pairing unlistenable. The Magni isn't the best match for the HD650, but it does a very credible job.
It would be nice if the LCD-X is less picky about amps, but on the other hand, if it has incredible resolution and transparency, it may be more likely to expose any flaws in the signal chain. The LCD-2 sounds great out of the Mjolnir, partly because it drives the LCD-2 a little brighter--I'm hoping the LCD-X won't get too bright out of the MJ.
The rev1 stock pads are not that good, almost borderlining on sucking. Putting on the LCD-3 pads makes a huge difference for comfort.
Two things:
- The LCD-X are targetted to studio audiences and balanced use is a requirement
- SE vs Balanced in terms of SQ is also a matter of amplifier topology. If your amplifier is balanced, then it will always sound better than SE. And the other way around.
It's just ridiculous nitpicking at these two details. I personally never used the stock balanced cable and always use aftermarket cables with my Audeze. Many don't even care about the stock cables whatsoever.
Hallo everybody from the CanJam,
i' ve just tried the Lcd-X with the stock balanced cable driven by the fantastic cavalli audio liquid gold balanced amplifier.The dac was the V800 by Violectric.
I've used some of my reference recordings(courtesy of Audeze staff.they are really nice people).I do audio mastering and i often use headphones.
I can tell you that first i've listened to the Lcd-3 with the liquid gold and the V800.
Then i've switched to the Lcd-x with the same setup using the same stock balanced cable and the same reference recordings.
The first thing i've noticed is that the output volume on the Lcd-x is higher than the lcd-3.
The Lcd-x is for me the best product that Audeze has now on the market.The tone and the frequency response is much more balanced
across the entire frequency spectrum compared to the top of the line model Lcd-3.
I could easily master a record using the Lcd-x because i hear the source in more balanced and clear way compared to the lcd-3.
The Lcd-x is also faster in transient response compared to the Lcd-3.
These are my initial impressions.
I think i'll buy one.
Recommended.
Recommended.
