I might be able to try a V200 before actually deciding to buy it. But i cant find much information about its output power.For planars, the key factor in an amp is current, rather than voltage. The 28.38 is good with planars because it can provide a lot of current. Conversely, OTL tube amps are great with high impedance phones, but not with planars, because of their generally low current output. Besides high power amps like the Audio-gd, planars tend to do best with current amps, like the Violectric (IIRC) or Questyle.
http://www.apexhifi.com/specs.html
Unfortunately, most of the time power output is listed in wattage or voltage, which means doing some math.
http://www.digizoid.com/power.php
https://www.rapidtables.com/calc/electric/Watt_to_Amp_Calculator.html
I have the Violectric v90 and it is excellent with the planars I have, including the X. I imagine the higher-end Violectrics only get better.
The 28.38 is probably the first amp i was looking at, but it is going to cost me allot since companies stopped taking them into the country many years ago. So i would need to order it directly. Can you Explain the sound characteristics on the 28.38?
