groovyd
- Jun 29, 2012
yeah their spec is way off or at least they are quoting the latest X weight vs the early version X weight of my unit. Their spec might very well be with the old style (non carbon fiber) headband too. My X weighs exactly 585g with the older upgraded carbon fiber headband without holes in the leather and with velour pads.
I swapped out the MX4 leather pads with an identical pair of old style velour pads which are significantly more comfortable and imho sound better in that they remove the sibilance and provide less recessed high-mids (something the MX4 is missing vs the X) since they are closer to the ear and sealed better then the MX4 style leather pads anyway. A bit 'smoother' sound top to bottom with the velour and the creaking of the leather when moving your head with the original pads is gone. To be honest I couldn't listen to the MX4 very long with the stock pads but the velour is making it much better and the weight actually dropped from 600g to 570g so as it turns out the pads themselves make up an unexpected 30g difference and bring the MX4 to 15g lighter than my X. Still I would have expected these to be much lighter overall. at least that was my hope, however I really can't argue for the price as long as the sound beats the X.
hard to tell by comparing the X and MX4 by using the Sonarworks custom calibration for the X but the overall sound appears more bass linear and cleaner but with less bass punch. highs feel extended but it is missing some of the midrange passion especially for female voices. have to continue to burn these in with the new pads and then send them off to Sonarworks for custom calibration before drawing any final opinions about the sound.
as far as looks are concerned I sort of favor the X to be honest. Is a bit more modest with less graphics and looks more like a professional tool while the MX4 looks more consumer headphone.
Here are both FR graphs per Audeze and also the measured custom calibration FR from Sonarworks for the X for reference. Totally an uneducated guess here but the MX4 profile looks like it would be a lighter and easier correction to reference flat especially in the highs. The X has some strange peaks in its response.
LCD-X Sonarworks
LCD-X Audeze
LCD-MX4 Audeze
LCD-X Sonarworks
LCD-X Audeze
LCD-MX4 Audeze
