x RELIC x
The ferrite cores did the trick in my case.
Chord Hugo 2 + LCD i4 is DEAD QUIET.
Colour me surprised! Glad you tried it and it sorted what you were hearing.
Enjoy!
I was wondering if the LCD i4 is mic compatible with:
-LCDi4+Cypher lightning cable+iphoneX, would the mic work?
-Also is there any third party cable with a mic that terminates with a 3.5mm jack compatible with the LCD i4?
good threadYup. Cipher Cable has a great mic for calls etc.
Has anyone experimented with other tips 3rd party ear tips? My groovy ones seems to be dropping off or get stuck in my ears when I remove the i4s. I’d like to avoid complys. Don’t like the feel especially in hot weather conditions.
Thanks.
I picked these up in Japan. No name/brand on the packaging but damn near perfect fit.Has anyone experimented with other tips 3rd party ear tips? My groovy ones seems to be dropping off or get stuck in my ears when I remove the i4s. I’d like to avoid complys. Don’t like the feel especially in hot weather conditions.
Thanks.
I love my I4's but cannot conceive of using them on a noisy airplane flight...not a chance,for that I use something that actually blocks out noise like the 846's or etymotic's etc.....in order to even hear the music on a flight I would have to turn the volume so high that either i would harm my hearing or disturb my neighbors or both!
Totally agree with this. To me the i4's are a bed listening IEM. Try wearing LCD-4s while lying on the bed and you quickly realize it isn't very practical. A soft pillow pushes the massive cups forwards and it feels odd. Furthermore although the i4 is open back, it outputs a lot less at typical listening volume than the LCD-4s. The i4 make for good traveling IEMs for when you reach a hotel room etc. But for a noisy plane, I think it is dangerous how loud you would need it to counter the engine and aircon noise. I simulated this by trying to listen next to an air conditioning unit and when I switched the aircon off I realized just how loud I had the volume.
Saying that, I have a newborn baby and the only headphone in my collection the wife currently lets me listen to in the bedroom are the Sony MDR-Z1Rs!
1. Yes, it works flawlessly
2. Yes, like the following cables. But the problem with these cables is, they won't apply the EQ and amplification like the cipher cable.
https://www.64audio.com/product/Cable-with-Mic
https://www.aliexpress.com/store/pr...147.html?spm=2114.12010615.0.0.419c3c2bjvCu9N
IMHO any iphone -> cipher -> LCD-i4 should sound much betterNow being an audiophile noob, would the LCDi4 theoretically sound better through:
-iphoneX -> cipher cable (with its built in dac) -> LCDi4?
or
-LG V30 (with its quad DAC) -> 64Audiocable with mic -> LCDi4?
Pleased to report that I’ve swapped the stock groove wear tips to the Spinfit CP100 and they work very well. It took a couple of tries to insert the tips onto LCDi4 but it works and the mount is secure unlike the stock groovy ones. I got fed up as the groovy tips got frequently stuck in my ears as I remove the LCDi4. The mount is not secure at all and seems to loosen over time.
The sound from the Spinfit seems very good - Listening to late night jazz as I type this with a grin from ear to ear.
