Just an FYI, I recently replaced my pads with Dekoni earpads on my 4Z, and I didn’t find it hard to do at all. But I had been conversing with Audeze because I didn’t like the clamping force of the carbon fiber headband. So they let me try out the spring steel headband, and sure enough, it clamps less and is more comfortable.
BUT while I was talking to customer support about that, I mentioned that I liked the Dekoni pads more than the stock pads. And then the rep told me we’re not supposed to change the pads ourselves, that it can damage the drivers, and that it can void the warranty!
So since my 4Z are brand new, the last thing I wanted to do was void the warranty. So they had me send my 4Z to them, and Audeze is going to, personally, install my new pads for me to make sure it is all done correctly and thereby making sure my warranty is not voided.
Anyway, just sharing that with you all. If you’re pad rolling, then tread with caution.
And no, there is nothing posted on their website about that, I brought that up and the rep said it’s never been an issue because most people are perfectly happy with the stock pads. And I was like, “We’re audiophiles, we love to tweak, tinker, and explore options. You need to formally address this somewhere on your website.”
Will they do that? I have no idea. But feel free to call them to verify all of this. They didn’t say if it also applied to the 4. But I thought I’d post this here just in case.
