Audio-Phile
- Dec 21, 2011
I did, I must have missed this. Hence my extreme confusion.
Regardless....given the output specs of the Hugo 2...it’s defintely not even close to capable of this sort of output. I believe it’s something like 94mW into 300 ohms, and given the moderate sensitivity of a 200 ohm LCD4...seems like it’s still not enough. Also...again...the voltage swing is something that you will want to maximize with these cans, or others like them. Overall, to put the type of current & voltage you really need into these things in order to make them sound good at all volumes & with all music, you need more than most amps can provide.
I’m almost certain that at one point I was told that my Mojo must have been “defective” in order for it to distort with the LCD4s, hence the point in bringing it up as an example of something that’s got enough power for most cans but clearly not enough for these. I stand by that assertion.
