Audeze LCD-2C Classic - Impressions Thread
post-14891655
Post #4,966 of 5,867
WildStyle-R11
A lot of people get their priorities wrong on head-fi due to lack of experience.
Your priorities must be (1) headphones, (2) amp, (3) DAC, (4) source files, (5) cables.
1, Headphones make the biggest difference. Find your preferred sound presentation and spend the most you can afford in that category. (Dark/bright, musical/analytical etc.)
2, Amps can bring out the best of your headphones but pairing matters a lot. Do your research. And spend the most you can after you have found your perfect headphones.
3, The importance of DACs is underestimated in this hobby. DACs can improve technicalities way beyond your imagination. Get the best DAC you can.
4, Poor mp3 will sound poor, regardless your fancy gear. FLAC is the minimum and must have quality.
5, Cables bring the subtlest difference. If you have got your chain sorted, play with it. However keep in mind, cables are only the cherry on the cake.
Well, I don't think you can apply it that easily. But generally people do underestimate the power of a DAC, albeit I withheld from them because I just couldn't find one that I liked. Mid-fi is easy, trade headphones till you find sound you like a simple Portable solution is fine... But I see a lot of people with 1k + headphones with a 300-ish portable DAC/AMP. What are you doing + pure silver cable... WHY?!
post-14891666
Post #4,967 of 5,867
betula
U.K.
U.K.
Of course, this five points is simplification, but you get what I mean in general.
For me also the most incomprehensible thing is when people own a collection of near TOTL headphones and use them with sub $500 gear. Also the importance of quality cables is way too overrated.
post-14891712
Post #4,968 of 5,867
Slaphead
Zürich, Switzerland
Zürich, Switzerland
Points 1, 2, & 3 I'll agree with
Point 4, yeah, kind of, a poor FLAC will always sound worse than a good 320 MP3, or even better, a good 256 VBR AAC.
Point 5, I'm a cable denier, so for me that shouldn't even be in the list. The only cable that I heard that made a difference was faulty.
post-14891739
Post #4,969 of 5,867
betula
U.K.
U.K.
FLAC/320mp3 very much depends on recording quality. A well recorded 320 kbps mp3 will sound better than poorly recorded FLAC. That's true for 256 VBR too. But in general, 80% of FLAC files will sound better than 320 kbps mp3.
I agree, cables are way too overrated. In fact they hardly make a sonic difference. (They do make a subtle sonic difference though.) What I find more important with a cable upgrade is aesthetics and comfort. These two qualities can improve user experience even more than just a subtle sonic change. Anyway, cables are at the end of my list on purpose.
post-14891756
Post #4,970 of 5,867
marcan
Point 4, yeah, kind of, a poor FLAC will always sound worse than a good 320 MP3, or even better, a good 256 VBR AAC..
Cough. There is no poor flac unless it's broken and you shouldn't hear the music (noise maybe). Flac is a lossless compression, it's like a wav but smaller in size.
In the other hand mp3 or acc are lossy compression, so it means your are losing something. The quality and the parameters of the encoder will have an impact on the perceived result. So unless you like the sound of the encoder which add quantisation noise and pre-echo, an mp3 or an aac can't be better than a flac if encoded from the same source.
post-14891777
Post #4,971 of 5,867
WildStyle-R11
As far as cables are concerned, There is probably a point where you can consider this, you know when you have spare 20k in your pocket. For me, I'm just getting quality cables, been using pretty much random interconnects, that I do not trust, replacing them with quality star quad and they will serve me years. Getting a new cable for my headphones for exactly as you say comfort and look. Silver plated litz if I am not mistaken, Well silver plated probably wasn't needed really, but it had more strands than the regular litz. So I just wanted to make sure my cans get enough juice. Which some of the stock cables on headphones do not *Cough* He 400i *Cough*. The only time I noticed a difference in cable. I could be wrong, will see when I get my cable. :D
Also anyone noticed that a lot of people mistake overly brightness for more detail? No, It's not more, it's just in your face.
I myself am setting up for Smooth and unaltering setup, which will lead to my headphones being the only thing affecting the sound. For my own sanity and EQ if needed, but so far seems like I don't even feel the need for more bass as with this setup it is more present, then it was before I got my DAC.
Reactions: phthora
post-14891782
Post #4,972 of 5,867
betula
U.K.
U.K.
Perhaps the most misleading and biggest dead-end street of this hobby nowadays.
post-14891837
Post #4,974 of 5,867
WildStyle-R11
The thing is, speakers are easy. Flat line. Headphones, not so much due to how close the drivers are to your ears and such, you can actually read about it on audeze site.
Could be peoples hearing as well, same as no one ever mentions that they use 24 band EQ, people might just not mention that they don't hear that well either.
post-14891907
Post #4,975 of 5,867
Jabba
Analytical sound gives a quick wow factor.
But in the long run, I love my vintage Sansui amp for speakers and headphones.
Sound so alive compared to a analytical amp with a illusional higher detail.
post-14892024
Post #4,976 of 5,867
WildStyle-R11
On a different note, do you guys think that the Carbon headband is worth it? This leather strap is getting kinda annoying lately.
post-14892092
Post #4,977 of 5,867
Slim1970
St. Louis, MO
St. Louis, MO
It’s pretty much the same design made out of carbon fiber. So it may be a little lighter but the leather portion of the headband will sit in the same spot
post-14892104
Post #4,978 of 5,867
WildStyle-R11
Thanks for the input. I'm surprised that there really aren't any after market upgrades available, even more when the LCD series is quite easy to take apart. It's really the lack of padding that is getting to me.
Reactions: Slim1970
post-14892183
Post #4,979 of 5,867
Slim1970
St. Louis, MO
St. Louis, MO
As cheap looking as Hifiman headphones look the are practically weightless on your head. This new Audeze headband is leap and bounds better than their old style headband comfort wise to me. I’m glad they incorporated it on all of their headphones. My first Audeze headphone was the LCD-3F with older style headband. When I upgraded to the LCD-4’s the comfort level of the new style headband alone was worth the upgrade.
I think if the pad wasn’t so close to the headband, like Hifiman and ZMF headphones, the comfort level of the Audeze headband would improve. Just my thoughts.
post-14892878
Post #4,980 of 5,867
xRaptorxPunisher
Isle Of Wight
Isle Of Wight
Well I've gone and done it.
Sold
LCD-4
Aeolus
HD650
Utopia
and the rest.
Kept
LCD-2C
Verum 1
Why?
LCD-2C at least my current unit hits like a sledge hammer. My only issue with them is the treble could be smoother but lets be real 99% of headphones have a rough, unrefined treble. Resolution IS on par with my old HD650 and Aeolus but planar drivers have an inherent lushness, fog you have to listen out for those micro details more. My previous unit was too laid back, there's good drivers out there it's a lottery.
Verum 1 was the other one I kept. It's like an LCD of old but more elegant, airy and liquid like. Deep bass, not as bold as my LCD-2C. I would say on the Verum those micro details are more obvious, resolution is close but I'd give it to verum slightly. The thing with the LCD-2C it takes time to appreciate it IF you're constantly comparing to other headphones.
I think with the Verum 1 and LCD-2C I'm done in this hobby. I've spent thousands on audio gear, I can retire happy Haha!
Reactions: omniweltall
Users Who Are Viewing This Thread (Users: 1, Guests: 1)
