Audeze LCD-2C Classic - Impressions Thread
Discussion in 'Headphones (full-size)' started by XERO1, Oct 7, 2017.
271 272 273 274 275 276 277 278 279 280
282 283 284 285 286 287 288 289 290 291
  1. Terozzzz
    It is just literally at point just putting plastic straws between your skin and pads. Trying to find some sort of plastic tubes what i can put under pads and the case of cups. Will put up photos when i make the mod permanent. In few days.
  2. Sound Eq
    i am curious how mids and highs will be affected as well with this mod
  3. Terozzzz
    There is easy way to find out, just lift the headphones from the cable plugs little bit of the skin. The sound change is audible right away.
  4. migasson
    I have no issues with the bass levels at all. They’re just fine. To any casual readers of this thread, and listeners of these phones, just stop reading this thread and enjoy your LCD’s. that’s what I’m doing
    nicknack40 likes this.
  5. onodera
    Do the straws actually work? I can't image the holes are big enough.
  6. Terozzzz
    They are, just 2mm hole is enough. They dont need to be same size as in 8" subwoofer :D
  7. WildStyle-R11
    It's about breaking the seal, nothing else... Besides it doesn't work for everybody.
    koover likes this.
  8. onodera
  9. malenak
    Guys, what do you think, what should be better accompany to LCD-2C? JDS Labs The Element or Massdrop x THX AAA™ 789 or Massdrop x Alex Cavalli Liquid Carbon X Amp?
  10. omniweltall
    Among those, definitely the THX 789.
    I'm curious about the Liquid Platinum though. I have never heard it.
  11. canali
    these are my first pair of audeze cans and i have to admit,
    these lcd2c are bulky and heavy.
    also I hear occasionally a slight hum in the wire, too.
    wonder if it's cable related or some cross electrical interference?
    might have to return them.
    (my original purchase was a buddy but those fell thru, these
    were almost same price as bstock from an ebay seller, with 30 day return)
    going back and forth with them and my hd6xx with my chord mojo.
    admit i was initially disappointed, expecting to be blown away by the audeze.
    sure there are some diffs but it's not night an day as i was (perhaps mistakenly) hoping for.
    the hd6xx have just become an even bigger value at the fab price (cdn200) that i got them for.
    this said, i'll continue to listen back and forth and get my hp listening skills back on track.
  12. betula
    Mojo is ok but not quite enough for the 2C. Extension lacks on both ends.
    I'd also recommend to give your ears time to adjust.
    snellemin likes this.
  13. Andrey2019
    My suggestion is to go with Mojo to a local audio store and check another pair of the same model.
    So that you will be sure that your particular pair is not broken.
  14. mixman
    I was thinking about getting a pair of classics, but I tend to prefer a more neutral or brighter sound. Should I look at the regular Fazon LCD2's instead or skip right to the X's?
  15. malenak
    And what about Jotunheim and Lyr3?
    Source: Chord 2Qute
