Audeze LCD-2C Classic - Impressions Thread
Discussion in 'Headphones (full-size)' started by XERO1, Oct 7, 2017.
232 233 234 235 236 237 238 239 240 241
243 244 245 246 247 248 249 250 251 252
  1. BrotherKathos
    I'm holding onto hope I just got a bad unit. It had a bad volume pot , so maybe other things were bad as well? I'll probably get it back in a week or two.
  2. BrotherKathos
    I'm still loving the LCD-2C
    See what I did there :)
  3. betula
  4. betula
    The reason you buy Audeze headphones: to hear those lowest notes with authority.
    loungecat likes this.
  5. Aliv3
    Can the WM1A drive these properly?
  6. TSAVJason
    The Source AV TSAVJason Stay updated on The Source AV at their sponsor page on Head-Fi.
    https://www.facebook.com./pages/The-Source-AV-Design-Group/153623164648713 http://www.twitter.com/TheSourceAV http://www.instagram.com/Thesourceavdesign http://thesourceav.com/ Products@TheSourceAV.com
  7. TSAVJason
    Yes no problem
  8. endlesswaves
    Yes. Only on the balanced 4.4mm.
    Got this just to try with my WM1A.
  9. betula
    It depends on what 'properly driven' means to you. I have never tried the WM1A, but looking at the specs it has 250mW output power in balanced mode. (60mW in single ended mode). While the WM1A will probably drive the 2C loud enough to an enjoyable level (in balanced mode), Audeze on their website recommends 1-4W output power for these headphones. Therefore on paper the WM1A is not the most ideal source for the 2C, you're better off with a more powerful full sized amp.
    While I enjoyed the 2C out of Mojo (720mW) there is a noticeable difference with my full sized amp outputting almost 2W.
    Of course power output is not everything, but it is a big part of the game. (Some of the less powerful amps might sound better than some lower quality but powerful amps.)
    Audeze does recommend more than 1W for the 2C. They must know why.
  10. Aliv3
    Thanks for the answers guys!
    I've never had an audeze and these are within my price. I will also use them on the PC but as I usually hear a lot of my music on the Walkman then my question
    Where I can buy this in EU?
  11. betula
    UK seems to have the best prices for the 2C in the EU.
  12. mksilent
    Aliv3 likes this.
  13. Frihed89
    I've never been able to figure out how to quote anyone.
    Nonetheless in reply to the comparison of the LCD-2 and the LCD-2 + Fazors, the latter has better bass, is more balanced through the sonic range (less warmth) is a lot more detailed and has better "inner resolution" of instruments and voices in classical and choral music. It also has better dynamics in terms of keeping up with fast, complex symphonic music. I have never heard any other Audeze cans.
  14. betula
  15. koover
    To reply to someone’s post, just go to their actual post you’d like to comment on, then go to the far right bottom of post and just select reply. You’re done and ready to go.
