WildStyle-R11
- Nov 6, 2012
Wellp, I have been playing with the loki + LCD2C and it's kind of mixed bag, depending on what you are listening to. +6 DB seems like a reasonable amount to keep on at all time anything more than that and it only works for very specific cases. All the other frequencies seem to be a bit too broad and off for anything to add to the LCD2C.
I found it amusing how I was watching and older show and adding the whole +12 DB made it more energetic, like it had a fake Dynamic range. I was thinking it is not far stretched. You got a lot of bass, you got mids in well the middle and you got highs that fall down a bit. For recordings that pretty much plays the same volume across the board, it might add some extra fun to be had.
In any case +6 DB is just enough to bring out the low end. May not be enough for a basshead like me, but can't do any more with the loki drags too far off into the mids. But Yeah +6 is good enough to make Nara sounds like it should, otherwise it sounds a bit flat.
Incidentally I found out that Ningen isu sound really good on the LCD2C.
And while casually surfing the interwebs I found out that Plantronics has finally updated their "Sport" range of headphones/Earbuds and now I can finally upgrade my original Backbeat fit to their newer ones that don't have the band that goes across the back the Backbeat fit 3100. Apparently they haven't done much to the sound judging by the reviews and that is good, I like the way they sound. Far too underrated earbuds. What is more the original went down only to 50Hz, the new ones go all the way 20Hz, there were few songs that did lack in that last bit of a stretch.
