Audeze LCD-2C Classic - Impressions Thread
Discussion in 'Headphones (full-size)' started by XERO1, Oct 7, 2017.
175 176 177 178 179 180 181 182 183 184
186 187 188 189 190 191 192 193 194 195
  1. nicknack40
    How do you install Reveal Plugin please id like to install myself i do have the USB stick that came with the cans.But i cannot use it with MusicBee with MusicBee only supporting Winamp plugin but KMann said if i install Eualizer APO i could use it with MusicBee that way
  2. ninetylol
    I installed Equalizer APO and loaded the plugin there following this post https://www.head-fi.org/threads/reveal-plugins-dsp-for-audeze-headphones.864146/page-2#post-13828923
    Looks like this atm:
    https://imgur.com/a/pAbKpV7
    [​IMG]
  3. interweb-tech
    Regarding Audeze plug-in. I pretty sure answer is no but is there a way to get it to play nice with Foobar 2K going through WASAPI (Amanero Technologies USB driver) that lights up the Audio-gd R2R-11. Equalizer APO sez it won't work with WASAPI exclusive mode drivers.
  4. nicknack40
    If it won't work with WASAPI mode then how does it work with the DAC bypassing windows. I currently use MusicBee in WASAPI mode no problems at the Moment with Headphones and Speakers with my DAC
  5. nicknack40
    Just looked myself and you are right t doesn't work with WASAPI which makes this application a waste of time for myself and others wanting to use WASAPI. WASAPI mode is the one i use which gives you full benefit of your DAC by bypassing windows if you cannot use WASAPI then makes using the DAC very much pointless to get the full benefit
  6. chef8489
    You should check out Jriver player. We pay all this money for audio equipment we should have a good music player. Jriver is only 50.00 usd. You can try it for free for a while. I actually like it much more than I do musicbee. https://www.jriver.com/
    gopack87 likes this.
  7. nicknack40
    That might not be such a bad idea. Ive been having few little issues with musicbee recently with music dropping out
  8. chef8489
    Give it a try. It has the features you were just talking about and you can use the reveal plugin as well as many others. It is so customizable it is crazy. Just have to look around the forum to get ideas.
    gopack87 and nicknack40 like this.
  9. nicknack40
    i know this is not headphone related but just installed jriver and using WASAPI mode but cannot control the volume on the jriver player and of course cannot change it via windows any idea how i change the player volume please im new to this player looks complicated lol
  10. chef8489
    Wasapi bypasses every control in windows for volume as far as i know and uses the amp attached to the dac. jriver should be at max as is. I will check when i get back tonight.
  11. rhern213
    My Reveal plugin is working just fine in Foobar2000 with WASAPI. I've used it with several DAC's including an Audio-gd amanero.
  12. chef8489
    OK with WASAPI and Jriver I can control the volume in Jriver player seen here
    [​IMG]
  13. anoxy
    If JRiver is set to exclusive mode, you control volume with the knob on your amp. If not set to exclusive mode, change it.
  14. SilverEars
    Just out of curiosity, what does exclusive mode mean?
    Anybody know of a music program(or specific setting) that normalizes the volume level of the music files? Puts them all in the same gain level?
  15. chef8489
    You can do that in Jriver. Just need to research how to do it.
    https://wiki.jriver.com/index.php/Adaptive_Volume
