Audeze LCD-2 Impressions Thread
Apr 13, 2021 at 4:30 AM Post #12,662 of 12,738
mikecheck95
ontario
Just ordered some new leather earpads from Audeze and they came with these "half moon spacers".
Do I still install these if I own an LCD2-F? My original pads did not have these spacers installed
they will fit on either side of the driver. It’s to help with preventing reflections off of the baffle.
Apr 13, 2021 at 10:22 AM Post #12,664 of 12,738
mikecheck95
ontario
Thanks! I wasn't sure if these were specific to a certain model or if we are supposed to put them on the LCD2 as well as mine never had any from factory.
That is a good question.. perhaps they're better suited to one model over another. But, damping acoustic reflections usually is a good idea.
Apr 15, 2021 at 4:27 PM Post #12,665 of 12,738
Yeezybop
United Kingdom
So I replaced the 3 year old earpads with a fresh set and it's like a new headphone. Wasn't expecting to hear such a difference in bass quantity and slam. It also fixed a slight channel imbalance and my ears no longer touch the fazors. The old pads looked fine but the foam was soft and they felt a little mismatched.
Worth considering if you've bought a pair used.
Apr 15, 2021 at 4:30 PM Post #12,666 of 12,738
Lohb
Surfing on electro
Are you talking about the freshly released official shallower pads ?
Apr 16, 2021 at 11:06 AM Post #12,668 of 12,738
mikecheck95
ontario
These were just like for like replacements of my originals, wasn't aware of a newer revision. I guess as the pads lose shape and soften up over the years it alters the sound signature a lot more than you realise until you A\B with a new pair.
Audeze has updated their pads. There’s a chance your old ones were just extremely worn down.
Apr 16, 2021 at 12:28 PM Post #12,669 of 12,738
Yeezybop
United Kingdom
Oh for sure - was just giving a heads up that if you buy a set used it may be worth investing in a new pair of pads.
My old pads did not look worn at all but the foam inside had softened which appears to have a noticeable impact on the bass response. More than I was expecting at least.
Apr 19, 2021 at 8:23 PM Post #12,670 of 12,738
angelus55
is it a deal breaker iyo if your ears gently touch the mesh inside the lcd-2 or any headphone for that matter? my ears ( right more then left) touch/graze the mesh slightly and i am not sure how i feel about that as i am not used to having something like that happen before
this is with the new pads, the old pad model i tried in the past did not have this issue
is it unreasonable to expect every headphone to completely not touch my ears even slightly? i am not sure as i dont know much about this matter
Apr 19, 2021 at 9:53 PM Post #12,671 of 12,738
mikecheck95
ontario
I’ve never had a headphone where this wasn’t an issue. The tips of my ears touch the fazors in the new LCD-2f as well... maybe the ZMFs or the Meze Empyrean would be a good fit but I’ve never had a chance to try either.
Apr 20, 2021 at 3:52 AM Post #12,672 of 12,738
Yeezybop
United Kingdom
Normal. The variance depends on the pads usually as they're handmade so never perfectly equal. My right ear touched the fazors on my old pads and my left ear on the new pads.
If it bothers you, you can contact Audeze they will send you some spacers that go inside the pads and keep the drivers further from your ears.
Apr 20, 2021 at 5:09 AM Post #12,673 of 12,738
Lohb
Surfing on electro
Empyrian have a good cavity for ear and no fazors of course...but those cans, the audio imaging and dynamics were not good with them when I had them IMO. Not good value for money to my taste.
Apr 22, 2021 at 11:14 AM Post #12,674 of 12,738
mikecheck95
ontario
After more listening time I am finding a little EQ isn't a bad thing in the female vocal range. I'm open to EQ recommendations.
Here's what I've settled on so far... This is based off of @metal571's EQ profile but is pretty heavily altered. I'll include a link to his EQ settings below. I'm curious how you are coming along with developing an EQ for yours.
Wanted to upload a photo of my set so thought I'd take this opportunity to do so. Still obsessed with how great they look.
Using Roon parametric EQ
*=optional
Preamp Gain: -5.5
Filter 1: Peak, 20hz, 3db, Q 0.8
*Filter 2: Low shelf, 105 hz, 1db (or adjust higher and compensate by lowering pre-amp gain), Q 1
Filter 3: Peak, 800hz, -1.5db, Q 0.8
Filter 4: High shelf, 1000hz, 1db (I have played with adding 2db and compensating with pre-amp gain.. I'm curious to hear what people think), Q 1.4
Filter 5: Peak, 3000hz, 1.5db , Q 1.4
Filter 6: Peak, 4100hz, 3db, Q 1
*Filter 7: Peak, 7000hz, -2db, Q 1.9
*Filter 8: Peak, 8800hz, 1.5db, Q 5
Filter 9: High Shelf, 10000hz, -1.5db, Q1.4
https://github.com/metal571/metal57...0de847e145bd334d1905b1254fff7e6a1999343222b4d
Apr 22, 2021 at 9:17 PM Post #12,675 of 12,738
tudedude
USA
*=optional
Preamp Gain: -5.5
Filter 3: Peak, 800hz, 1.5db, Q 0.8
Thanks, nice photo.
