Just arrived. These definitely look like the new pads. I don't get the complaints of about weight, these don't seem unusually heavy to me.. I don't feel the need to EQ either, at least for the type of music I listen to. F*ck these are sexy. Shedua wood is gorgeous.
Audeze LCD-2 Impressions Thread
- Thread starter DefectiveAudioComponent
Mine turned out to have the new pads as well. I've been extremely pleased with my LCD-2F for sure
mikecheck95
you can tell by the way they kind of collapse around the sides. I’d say they look like the new ones. My wood is not nearly that beautiful.. you got a really nice set! Also... how are you driving them? I’m still trying to figure out what amp to get for mine.Just arrived. These definitely look like the new pads. I don't get the complaints of about weight, these don't seem unusually heavy to me.. I don't feel the need to EQ either, at least for the type of music I listen to. F*ck these are sexy. Shedua wood is gorgeous.
Yeah I'm totally stoked about how the the wood came out. I'm driving it with a the Schiit Magni 3 using a focusrite Scarlett 2i2 as the Dac. I'm not really picky about amps and dacs. I need to get an adapter so I can try out the Fiio Btr-5.you can tell by the way they kind of collapse around the sides. I’d say they look like the new ones. My wood is not nearly that beautiful.. you got a really nice set! Also... how are you driving them? I’m still trying to figure out what amp to get for mine.
Lohb
Lovely wood and finish on them...chomping to try a set vs the first version 2010.
Lohb
BTR5 which I own, will give you 'medium volume nice sound' but its a choke in the ability of those cans.I'm not really picky about amps and dacs. I need to get an adapter so I can try out the Fiio Btr-5.
I only use BTR5 for netflix and a projector with my Aeon2Cs...and BTR5 puts more focus on the mids (voices) which works for me....
If you dig on headfi you can get decent DAC/Amp combos and not too pricey these days that will really release the LCD-2 sound.
r2r and THX 887 was perfect for my 2.1 LCD-2 but again it has a totally different presentation to the new ones...dark and thick.
Really if THX887 were around in 2010 I don't think there would have been the complaints regarding treble roll-off/soundstage/instrument separation etc...it totally slapped 2.1s into shape....totally great synergy with them.
Even E1DA9038D (clinical - max detail extraction) + JDS Atom
...sound at this price unheard of even 3 or so years ago...maybe
or Schiit Modi Multibit (warmer/fuller) + JDS Atom will give you way more than BTR5 could ever do....
LCD-2s 'easy to power' on new gen. still need that overhead current reserve for complex bass and mids.
I am using Valhalla 2 and Jot 2. Both work very well and give different sound signature which is quite funyou can tell by the way they kind of collapse around the sides. I’d say they look like the new ones. My wood is not nearly that beautiful.. you got a really nice set! Also... how are you driving them? I’m still trying to figure out what amp to get for mine.
totally. I have a btr5 with hd6xx, sounds so much better as bluetooth than wired... jds atom plus dac so much better.BTR5 which I own, will give you 'medium volume nice sound' but its a choke in the ability of those cans.
Have you tried the Btr-5 balanced with the Lcd-2? I just ordered balanced cables from Hart audio for the Btr5.BTR5 which I own, will give you 'medium volume nice sound' but its a choke in the ability of those cans.
I noticed this too with my Focal Radiance.totally. I have a btr5 with hd6xx, sounds so much better as bluetooth than wired...
After more listening time I am finding a little EQ isn't a bad thing in the female vocal range. I'm open to EQ recommendations.
Check these out: https://www.head-fi.org/threads/audeze-lcd-2-2-pads-original-unused.956134/Dekoni Sheepskin Elite came in, going right back. Compared to the stock leather pre-fazor pads they remove a whole lot of the sub-bass and make the mids really off for my ears, I don't even know how to describe it. It sounds fine for the most part, but putting back the stock pads makes everything just more natural. Might just be different, not for me.
The one positive is it further removes some peaks and that is nice, but not worth the tradeoff. Was really hoping these were the pads for my glasses but the hunt is back on. Also removing the pads on my Classics was at least possible without damaging them too much.... My god they really don't want you to remove the pads on the pre-fazors. If I ever decide to sell it (Doubt it) Might have dropped the value by $50 at least now, the pads work just fine and still look fine, mostly, but you can tell they were removed.
Really think Audeze needs to rethink this whole glue think in the future. It sucksssssss.
Lohb
It will be better than the SE connection, if only because the voltage is doubled and the mWatts output headroom will probably 30% or so be higher.Have you tried the Btr-5 balanced with the Lcd-2? I just ordered balanced cables from Hart audio for the Btr5.
I've been using just a single peak filter of +4 dB @ 3800, Q factor=0.9 and really liking it. It helps pull the mids forward a bit.After more listening time I am finding a little EQ isn't a bad thing in the female vocal range. I'm open to EQ recommendations.
Just tried it, yeah that seems to be the region giving me issues. thanks.I've been using just a single peak filter of +4 dB @ 3800, Q factor=0.9 and really liking it. It helps pull the mids forward a bit.
