Audeze LCD-2 Impressions Thread
post-12559608
Post #8,296 of 12,308
LinkPro
So I just pulled the trigger on a LCD-2 Aluminum... It was $250 off and I've never had or listened to an ortho before (except for a beat up T50RP at a studio) so I thought why the heck not. My only concern is the weight because my crown is a really weak point and I've had to return headphones that sound amazing but lack the proper padding on the headband which will start hurting my head 1-2 hrs in.
I'm going to drive it straight out of my laptop's headphone jack for now - the audio solution is from Creative and has a lot of gain so I won't have an issue volume wise. I do plan to buy an amp later - would something like a Magni 2 be a good match for the LCD-2?
post-12559733
Post #8,297 of 12,308
jodgey4
Sad to say, you might have to spend that $250 saved on the carbon headband, it's a pretty heavy can. Magni 2 would be great, plenty of power :).
post-12559739
Post #8,298 of 12,308
TexasBuck
The weight/padding on the headband is cause for concern.  I could only listen for 40-50 mins without the top of my head hurting.  There are  solutions though.  There are a couple straps you can get that distribute the weight over a larger area.  Fellow Head-Fi member "Lohb" sells one of them.  I just got mine tonight.  I listened for a couple hours without pain.  Here is the link:  http://www.head-fi.org/t/805211/head-cushion-strap-for-audeze-hifiman-fostex-th-x00-denon-dxk
post-12559748
Post #8,299 of 12,308
Ampeezy
http://www.ebay.com/itm/Audeze-Unofficial-Leather-Head-Comfort-Strap-Pad-/182117649518?hash=item2a670ecc6e:g:KMIAAOSwstxVGPQu
Yeah you might wanna get one of these...not too pricey
post-12559773
Post #8,300 of 12,308
LinkPro
Thanks guys, I will look into those if necessary. Looking forward to getting back to high end audio with these. Curious to see what orthodynamic tech has to offer.
post-12559986
Post #8,301 of 12,308
Headmate
Munchkinland
Munchkinland
You will find the LCD's amazing, just the comfort is a huge letdown
make sure u get a clean sounding amp like O2 or magni2, because LCD's appreciate transparency in sound chain.
post-12560114
Post #8,302 of 12,308
DavidA
Hawaii
Hawaii
My GF was listening to the LCD-2 and asked for a drink so this is what I made for her:
Its a champagne sunrise vs tequila sunrise, goes great with the lcd-2
Reactions: jodgey4
post-12560159
Post #8,303 of 12,308
obsidyen
Cambridge, UK
Cambridge, UK
Only to 2016 LCD 2 owners: How is it with EDM? Bass impact, punch, slam?..
post-12560427
Post #8,305 of 12,308
g4747
For best sound quality:
Look up how to set up Foobar2000 and Windows for bit perfect.  I use the Meridian ASIO E2 driver.
I set Windows Sound to 16/44 so that I can play MQA files.  If you are playing other hi res files, set the output to match the source file.
Foobar volume should be at max.  Windows volume should be disconnected (if you are using the line out from the E2 to your amplifier).
Control the volume at the amplifier.
For remote volume control:
On my iMac (running Windows), I can use the headphone out on the E2 to my amp, and use an Apple remote to change the volume going through the amplifier if I am too lazy to get out of my chair.
Thanks...
I downloaded the ASIO driver, I was using Wasapi for MQA files. Is there much of a difference?
I used the right input of Meridian (I was using the headphone one).
I changed the sound outpout of the Meridian through Windows to 16/44.1, as I thought that higher is better.
NO artifacts.
Also, I contacted customer support of Audeze, asking about the driver update of the newer models and their support was excellent.
  HI George
Thanks for your inquiry. I've attached a current average FR Graph of the LCD-2s for your examination. All current production is within 1dB of this graph.
We feel the current versions of our drivers offer a modest improvement in sonics but the differences are subtle and may not be noticeable except in direct A/B comparisons.
We hope that our quest for improvement hasn't caused too much concern, and we're very confident that your headphones are among the best in the known universe.
At this time we can only offer upgrades in the form of driver replacement, for which we charge $250 in the LCD-2s.
Thanks again for your support, and we wish you very happy listening!
All the best
post-12560485
Post #8,306 of 12,308
Headmate
Munchkinland
Munchkinland
Lol I thought it was orange juice
post-12560743
Post #8,307 of 12,308
mkarikom
My EDM litmus test is Alarm by Boys Noize.  This is a really thick and heavy track and the LCD-2 simply nails it with detail and slam.  Ditto with stuff like deadmau5' 4x4=12.  On those tracks my Fidelio X2's, which are great for cases where I need something that works without a desktop stack, and have more bass emphasis than the LCD-2, sound muddy in comparison to the LCD-2.  Hope that helps!
Reactions: obsidyen
