Audeze LCD-2 Impressions Thread
541 542 543 544 545 546 547 548 549 550
552 553 554 555 556 557 558 559 560 561
  1. Ampeezy
    Good choice mate, glad you are enjoying these. It really gets better as you get more used to the sound and learn to appreciate the nuances in the phones.
    [​IMG]
  2. g4747
    My portable chain is laptop- meridian explorer 2-objective 2-Lcd 2.
    From which one should adjust the volume?
    Foobar, laptop (it's common with meridians as when I adjust one the other follows accordingly) or objective?
    Right now I have meridian laptop and foobar at max vol. and I am adjusting the objectives knob.
    Does that insert any hissing as I have the other volumes at max?
  3. Ampeezy
    Adjust only from the O2 i think, volume control should be strictly analog if it can be helped. Think you got it right mate.
  4. PinkyPowers
    The whole purpose of the amplifier is to control volume.
  5. Devarika Woulf
    Yeah, my LCD-2.2 is smooth as anything. It was that relaxing sound that initially drew me to buy then keep it, with my gear trying to emulate a vinyl system. You can throw anything at it and it handles it wonderfully without being too harsh yet keeping great resolution. That guy must hear differently from us. I've never heard a HD650 but everything I read said the LCD was easily the better headphone.
  6. LEGendARY
    I find it odd when you have the equipment right in front of you to test and see for yourself, but you resort to asking other people about it!!
    I read that if you use software to control volume it would degrade the sound, but If I can't hear it, I don't give a damn.
    So in my case, I do use the software to control volume while leaving my DAC/AMP on a higher than normal listening gain because if I go lower, my LCD-2 probably loses some of the overall authority. It could be just volume though!!
  7. Ampeezy
    chill fam
  8. LEGendARY
  9. g4747
    Thank you for your answers.
    My reservation comes from the fact that I THINK that I hear noise  when I'm having everything maxed out and just adjusting the objective amp. On the other hand having the volume adjusted at 3/4 on my objective permanently, the foobar one at full volume and playing with the meridians (and also windows) volume corrects that.
    I don't know if that makes any sense or it's just my ears.
    These guys will take their attitude somewhere else eventually.
  10. Alchemist007
    Does anyone notice a change in quality of sound depending on the preamp used? Just wondering as I'm looking at buying a tube amp and using my o2/odac as the dac and preamp.
  11. LEGendARY
    Hahaha Why so sensitive man?! Did I offend you in any way?
    I just thought that actually testing things, in general, and hearing the difference is better as long as you have equipment.
    Anyway, enjoy the music.
  12. PinkyPowers
    Every part of the chain impacts the sound.
  13. marcan
    It depends on the bit depth of your source and your DAC. If you decrease 6 dB digitally, you decrease the definition of 1 bit. So if you have a file at 16 bits and you play it on DAC at 24 bits, you still have theoretically a definition of 23 bits. Practically DAC rarely have more than 20 bits of real definition so you are still in the sweet spot of your DAC.
  14. g4747
    Well usually my Flacs are 24 bits/ 44.1 kHz at best, I can't always find 24, I sometimes have to choose 16.
    Meridian is capable of reproducing files of 24-bit/192kHz and I find that the right sound volume for me is around -20 - -10 dB.
    The weird thing is that I think I'm hearing artifacts when meridian is maxed out and I'm playing with the amps volume which as I understand shouldn't happen.
    I can't think of any other volume combo to try, maybe my gear is very particular when it comes to volume (or even faulty?).
  15. fiascogarcia
    My Hugo clips if I use the line out setting to my amp, which I wouldn't think should happen either.  But all I had to do was dial the Hugos volume level back.  Just reduce the DAC volume, then use your amp volume control for adjustment.  IMO
    g4747 likes this.
