Audeze iSINE 10 & iSINE 20: Audeze releases two new IEM planar magnetic earphones
453 454 455 456 457 458 459 460 461 462
464
  1. Fishdo
    I found the same myself mate..but between the i3 and 20 that is.... I had the 10’s and 20’s and got the i3’s as soon as they were available here... I didn’t have the 20’s when I got them as I sold one to get the other... so it wasn’t until I was able to compare my i3’s with my friends 20’s that I could make a good comparison (personal) as before that I was relying on memory....
    Must say I was underwhelmed once I did and wished I hadn’t done so.... so much so I sold them... not that they were bad I guess it’s more that niggling you get when you think you didn’t need to spend even more for an iem that isn’t always a practical option for me (with the open back that is)
    I would have kept the 20’s if I could make that choice now....
  2. Br777
    WOAH! now we're talking! This is a whole new level of perfect fit, and now i can rotate the fins to fit my ears better. Having both the angled hooks, and the fins at the same time is a LOT more secure on my head! This makes these headphones significantly more wearable for me. They fell off way too easily before. Now they're really locked on and still feel very gently secured. This is amazing!
    You should advertise this as the best way to use these, or redesign them to integrate better this way or something. Especially making the fins rotatable and not locked into place by default. being able to rotate them makes them much more fit-able.
    Thanks!
  3. clerkpalmer
    Yeah this was genius. This is my go to setup on my i3.
  4. Matpar
    Hi, still have trouble in finding the ear fins here in EU.. any help? Thanks
  5. iranonfr
  6. Matpar
  7. metaldood
    trellus and showme99 like this.
  8. eldss
    Can someone from @Audeze advise if there will ever be a plan for the 4th button on cypher cable? To date it just seems like a waste of space? Couldn’t it be used to switch over eq settings etc?
  9. Audeze
    It is used to mute/unmute the microphone.
    Audeze Stay updated on Audeze at their sponsor page on Head-Fi.
    https://www.facebook.com/AudezeLLC https://twitter.com/audeze https://www.audeze.com/
    trellus, Ynot1 and eldss like this.
  10. ssvijay
    Any update on this :frowning2:
  11. Ynot1
    Just another application with minimalist approach.
    I can't really say what is better about this way other than it was not too expensive parts wise.
    Less than a dollar head band, less than a dollar super glue, less than a dollar copper wire, less than a dollar heat shrink and rubber tube, everything else is priceless ["AUDEZE"].
  12. griga
  13. Deckard916
    I want those so bad, ear issues are keeping me from using my 20s currently. Ordered the LCD MX4s instead, maybe next year I can finally pick up the i4s.....
  14. Dimos Zagaris
    I have one quesition cause now i will take isine 20 for recording vocals..Do you think they isolate well for recording vocals or i have leakage problem with my large condenser microphone?
  15. Tai1or Made
    No, they won't isolate.
    I wouldn't use any open/semi-open headphone for tracking.
464
