Audeze iSINE 10 & iSINE 20: Audeze releases two new IEM planar magnetic earphones
451 452 453 454 455 456 457 458 459 460
462
  1. Fishdo
    Thanks @TheStalker79
    Hopefully it will also have a couple of pairs..
    Cheers
    TheStalker79 likes this.
  2. TheStalker79
    Well after ten days with the new accessory kit, I've actually gone back to the original flat earhooks.
    The fins are fine for the first hour or so, but anything more than two hours and I find them uncomfortable. Whilst they fit in my ear quite snug, there is a bit of a learning curve trying to find the best angle to have them at.
    As for the curved earhooks, they made the 20s feel too loose on/in my ears. Each time I moved my head, I could feel them moving around. Tried both sizes and had the same issue. By contrast, the flat hooks really grip my ears and there's no movement whatsoever.
    kukkurovaca likes this.
  3. Devodonaldson
    Did you try a slightly larger eartips? Yes the new earhooks are too loose to say exercise with, but for me at least they are secure enough to move Round with, clean, etc without issue and without discomfort.
  4. TheStalker79
    Tried medium and large. I use large with the regular ear hooks and they're just right. Sadly, with either size, the new style hooks just don't work for me.
  5. Fishdo
    I’ve just been trying the angled earhook and conch cup on the i3’s and definitely prefer the earhook over the conch cup and the angled over the straight however to get the comfort right (for me) I tried a number of ear tips... I still don’t like the Audeze ones... I didn’t like them on the 10 or 20 either... not just the fit but also the sound I heard...
    So then I tried Comply smart core and the T600 both of which I still don’t like with these i3’s.. comfort is okay for an hour or so but the sound is not as good it sort of reduces the soundstage and makes it too warm for me... I then tried the Spinfit 155’s which were comfortable but still didn’t feel like they were properly in my ears (I tried small and medium) and I’ve settled on the Spinfit 230... which for me are perfect... they go nicely into my canal with nice depth and they allow the sound to be opened up...
    Now I’m off to try some porridge and my neighbors beds...!!
    Love the sound of the i3’s .... sound quality and definition is really nice with my mojo. The cipher cable is nice but at the top end the detail blurs or rather distorts (which I thought it wasn’t supposed to do?!) .... the BT cipher is nice but nowhere near as loud (I tried a few sources like Quboz Tidal etc plus direct through Onkyo HD) sounded very limp but better than it did on the 20’s ...
    I haven’t bothered trying the 3.5mm standard cable.... just used my Linum BAX and a few cheaper cables like TRN HiFiHear and Yinyoo ...
    For me they are definitely an upgrade on the 20’s..
  6. Devodonaldson
    Are you using these in your computer and eq'd with the mojo, or stock sound?
  7. Nec3
    [​IMG]
    It's nice. Sacrifices bass control and quantity. i.e. 20hz to 150hz transitions in music is more coherent with the stock cable, there's also a more apparent roll-off in sub bass in favor for more midrange control (especially that 1.3khz bump) and treble smoothness. Too bad I don't have balanced output which the cables were meant for. I'd say it was a nice trade-off, as I prefer these as daily drivers in terms of comfort over Sennheiser HD600's.
    It's also relatively affordable :)
  8. Matpar
    Doing something similar too, I've paired the 20 with a Bengkel Macro cable (same used for the Edimun) with 7n full copper wire, no nylon inside: flat frequency response, so it does not color sound, instead so far I've seen an improvement in detail and separation, basses are incredible (they seems "visceral", coming out from nowhere? :)), and in general it seems planars works better with less "effort" (dunno how to express this in other words), and are more "alive" than with stock cable.
    I am using also another custom cable with silver and balanced 2.5, very close in terms of separation and detail, but with the iSine I believe there is less sinergy.
    Fishdo and Nec3 like this.
  9. metaldood
    Got tired of waiting for the Anker cable to come back in stock on Amazon US so ordered from UK. Took 2+ weeks for delivery. Works great on Pixel and Macbook.
  10. Ynot1
    https://www.ebay.com/itm/Anker-USB-...971090?hash=item4b693a3b12:g:aq4AAOSwrxFdWg1J
    Hopefully if they run out they will make more and lower the price too.
    Also these just barely fits and I liked them better than the stock and even the Hifiman's.
    https://www.aliexpress.com/item/33004214316.html?spm=a2g0s.9042311.0.0.40c84c4dYxm14x
    Tackiness of silicone helps keep the ear piece stable.
    Because the ear hooks acts as a hanger, I felt the better cushioned ear tip made a good improvement to comfort.
  11. metaldood
    Anyone on Android with UAPP notice the music plays really sloooow. Not sure what's going on. Normal playback with Google music, Spotify work fine.
  12. rkw
  13. metaldood
    I forgot to mention this is with the Anker usb-c cable.
  14. Maximiliano Campo
    Hi guys,
    Does anyone know if the Cipher Bluetooth cable can work with headphones which are not Isines?
    Can I connect my R1 Zenith headphones to the bluetooth cipher cable and it work?
    Thanks in advance.
  15. rkw
    The Cipher cable will work with any IEM that has a matching connector (I don't know if the R1 Zenith is compatible). However, why would you want to? The whole point of both the wired and Bluetooth Cipher cables is that it applies equalization to fix the frequency response of the iSine IEMs. If you use it with any other headphone, the sound will be equalized in the wrong way.
462
