Audeze iSINE 10 & iSINE 20: Audeze releases two new IEM planar magnetic earphones
392 393 394 395 396 397 398 399 400 401
403 404 405 406 407 408 409 410 411 412
  1. Devodonaldson
    Amazon has plenty of reasonable priced 2.5mm balanced 2 pin csbles. I went with 16 core just cuz I like the look of the extra thickness
  2. m8o
    Much thanx @KMann. Hope you can answer a follow-up.
    When I use my Android based phone as the BT stream source, what tells / how do I tell the BT Cipher cable that I have an iSine 20 connected, so that it applies the correct DSP program?
    Thanx!
    P.s. are you planning to attend CanJam NYC this year? Look forward to meeting you, if that is an affirmative.
  3. Maximiliano Campo
    I'm not sure where in the world you are, mate, but this is a very good balanced cable at an affordable price. The connectors fit stronger than the included Audeze cables.
    Mal Waldron likes this.
  4. Mal Waldron
    Well, I have the iSINE 10 since this morning and I'm still hallucinating with them. I've been testing them on the Sony WM1A dap (not burned yet) with several high resolution jazz albums and some electronic ones. It's amazing the scene and instrument separation of something so small, the accuracy of all the frequencies and why not say it ...the comfort! I had read some criticisms about how difficult they were to place correctly and I don't agree at all. In fact, they are the iem (if they can be considered an iem to use) more comfortable than I have had. I'm using them with JVC Spiral dots. By the way, in the end, I received by mistake the version that includes the cipher cable, but as my phone is not Apple I will not be able to prove it.
    ¡Very happy with this wonder of sound engineering!
    Edit. Not using any kind of EQ
    HeavenNotes and Devodonaldson like this.
  5. Sir Metal
    They're selling the Bluetooth CIPHER cable in the UK now.
  6. Devodonaldson
    I was feeling like the only other person who thoroughly enjoys my isine sans eq. Isine 20 and Comply foam .I don't like thesoundof silicone
  7. Mal Waldron
    I will try the foam tips. I usually use them when I'm walking or in a noisy ambient.
  8. Devodonaldson
    I like them due to warmer/more accurate tone IMO. Not all foam created equal. No deep insertion. Silicone makes the treble a little tinny while reducing body of the miss, to my ears
  9. slowpickr
    Correct me if I'm wrong, but don't the iSines take a notched or slotted connector? Therefore, regular 2 pins cables won't work?
    To reiterate a previous post, I'm curious if the BT Cipher cable produces better sound quality than the standard cable using 10 band EQ out of a DAP or ES100. Any comments appreciated.
  10. masterstroke
    Definitely a two pin on the 10 & 20.
    Couldn't say yet about SQ comparisons, far too early, but usually a wired connection wins over BT.
  11. KMann
    The DSP tuning is already baked into the BT cipher cable and should work iSin10-/20/LX. The tuning is very similar to the one in Cipher V2 for iSines.Nothing else is needed from your Android or any other BT device pairedd to it.
    I will not be there but Audeze will be represented.
    Grimlock248 likes this.
  12. showme99
    You are indeed correct about the need for a notched connector. If that notch isn't present, the cable won't fit.
    slowpickr likes this.
  13. m8o
    I see then that I was mistaken all this time that each model [10/20/LX] got it's own eq curve.
    Thanx for the add'l info.
  14. Heavyboxer
    Enough information for me, just placed an order for the cables. :)
    And your local distributor here is charging USD 800 for isine20 without the bt cable. No chance.
  15. masterstroke
    Cipher V2 for iSines? When did that happen?
