azncookiecutter
- Apr 25, 2005
No, kids. Do not believe anyone who says its a personal preference thing. In terms of signature as he said, this is true. But 99% of all the other aspects there is usually a clear winner and you really cannot debate it. Signature style and presentation in soundstage, and earpad style are really the only things you can debate. The M50 is a great set, the 750 DJ is better. My rating of each, if i missed a category let me know and ill add it in
M50 Vs 750dj point rating, 1 point for each area if it beats the other
-Bass Amount - 750dj
-Bass Quality - 750 dj
-Clarity side by side - m50 but it was very close
-Versatility to play multiple genres well - 750 dj ( anyone willing to debate this? please feel free by testing classical and jazz on the m50 )
( separation on the 750 dj is clearly better and able to play classical and jazz incredibly well, while having perhaps the best coloration and presentation for rock and metal that ive ever heard in a sub $200 set )
-MSRP price - 750dj at $160 and M50 at $200
-Impedance - 750dj at 32ohm and M50 at 38ohm
-Sensitivity - 750 dj at 106db and m50 at 99db
-Isolation - Give it a tie both are at 12db
-Detachable cable option to upgrade to a higher quality cord easily - 750dj
-Cable and connector quality - Tie, both use similar set ups
-Harmonic Distortion - Also a tie, too close to really care much
-Weight -750dj - 227g and m50 at 284g
-Wider Freq. Response - 750dj 5hz - 30khz and m50 at 15-28hz
-Driver Size - 750DJ at 50mm and M50 at 45mm
-Earpad softness and quality - m50
-Earpad heat dissipation ( which one stays cooler and avoids getting hot ) - 750Dj
-Headband fit - Tie, both have the right style arc for a human head without leaving lots of space on either side a'la Shure 840 style
( however, the 750dj vanishes on your head after a short time and the m50 never does. Even though the earpads are not as soft as the m50, its clamp and overall angled design allows for them to rest on your ears with almost no clamp at all, the m50 does not do that )
-Build Quality - Ohh a tough one, this is debatable but I will say the M50 is more solid feeling but im terms of which plastics used on either set is more durable and strong? Ive not a clue really, and dont want to break my sets to find out![]()
im not trying to be a jerk, but in case you have never searched head fi before, there are topics left and right and all over the place asking which sets are the best for X value, and more than usually the same sets are listed for each. The 750DJ is an overall better value and is harmonically more versatile for listening to multiple genre, it also has high quality bass and more of it. *salutes
Almost half of these comparisons have no real value, for the sake of objectively comparing between both headphones.
