SikkNazty
- Dec 17, 2010
Currently have a Sager NP9150 laptop.
Anyone have any opinions or suggestions?
BF:BC2 and BF3 also aren't what I'd call shining examples of positional audio, either; the sound samples themselves are great, but the positioning is substandard even compared to most other software-mixed games, let alone the first four Battlefield titles that use DS3D or OAL. I have a hard time figuring out where sounds are coming from no matter how I mess with the settings.
The Codemasters racing games are an unusual exception; they still use OpenAL, but instead of expecting you to own a Creative card to get the most out of it, they come bundled with Rapture3D, which can do binaural mixing (with six different HRTFs to choose from!) in software. This is the approach that the game industry should have went with, but for whatever reason, they didn't.
Asus isn't particularly stable and has enough bloat as it is. UNi Xonar is a good place to read about it and get alternative packages.
Also, Asus GX feature is quite poor, delivers worse audio effects that are also more buggy, and it's EAX emulation doesn't emulate hardware features at all, with some of those actually being present on USB (software based) X-Fi solutions.
If it was the X-Fi Go! (SB1100), then I would recommend the X-Fi Go!, which has a surprisingly clean output (considering it's a USB dongle) and gaming support is still better than the Asus USB alternative, despite running solely on software.
I have both. Xonar U3 wins here, simply for DDL and the far superior DH compared to the crappy THX. For stereo SQ, both are so good, with GO! edges over a slight.
In regards to the U3, have you come across a "fix" for the issue where the sound will drop out, then come back when you move the headphone jack around? I've read of many users with this issue and the U3. I also have the Creative Labs Go!, but I've kept it sealed in the box in the event the U3 works for me, and then I would potentially return the Go!
Thanks,
Sounds like a poor headphone jack or poor soldering job of the jack to the board. I would likely think it is a poor solder job. These are soldered by machine & often only spot checked by humans prior to assembly.
