Traveller
- Jan 8, 2004
It's all good and well that the AK3xx can "identify" a call from a AptX HD device, but this alone in no way guarantees that the AK3xx will actually operate in AptX HD mode... . As you (and many others on the Internet) pointed out, the CSR8675 is a requirement for AptX-HD support...
Are you suggesting the AK380 displays AptX HD and then actually goes ahead and just uses AptX? ... I agree that it seems very unlikely the CSR8675 can be in the AK380 unless they had early access to the chips which DOES happen in the industry... .
I'm only suggesting that the timeline is against us but I do trust A&K (as well as iRiver - manufacture of my first serious DAP - the iHP-120*). Enough that I recently parted with a lot of € for their AK320
...There is a whole separate question about whether the AK DAPS are "really" outputting APT-X HD, considering that the Qualcomm chip that supports this came out over 6 months after the release of the AK380 and of course a whole lot longer with the AK240. The screen shows APT-X HD on the DAP when connecting with the XB10 but conspiracy theorists believe that is all it does by identifying the stream header, and then just transmits with APT-X (no HD) anyway
I did try and put the conspiracy to bed by contacting Qualcomm directly to ask if there were other ways of implementing APT-X HD without the newest BT radio chip (e.g. in an FPGA), and whether they planned to certify the AK DAPs........no response, unfortunately.
...As for the question of the 320's ability to use the AptX-HD codec, I have no way of verifying it. I would need an AptX-only headphone dongle so that I could plug in the same headphone / IEM into both BT-dongles. This would provide the means to properly compare 16-bit AptX against 24-bit AptX HD.
While I still am without the ability to A/B, I was pleased to see Qualcomm add the AK3xx/AK70 to their AptX HD list!!!
